10-09-2020, 02:53 PM | #253 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Thanks for your fine efforts!!! Cheers! |
10-09-2020, 09:05 PM | #254 |
Fyi: My OP has been updated to include Turbo2ltr member's excellent lable per post 242. Cheers!
11-15-2020, 12:58 AM | #255 |
Drives: 2018 ZL1, 2001 Z28 1LE Join Date: Dec 2013
Question, I've been to the same track for 3 separate events the last 3 months and have kept it in just track mode for the time being. I'm beginning to feel more comfortable with the car and track and overall racing around a track vs straight line..
If I'm reading this correctly, I would benefit from moving into PTM Sport 1 which will ease back on the TCS cutting in as seen in Track only mode? (Not sure what high slip means in the chart) |
11-15-2020, 05:43 AM | #256 | |
Drives: '18 1SS 1LE Join Date: Sep 2017
'18 1SS 1LE Black, PDR
11-15-2020, 07:03 AM | #257 |
11-15-2020, 12:46 PM | #258 | |
Note that Sport 2 shuts down Stability Control. Have fun and cheers! |
05-18-2021, 10:50 AM | #259 |
Drives: 2021 Camaro 2SS 1LE (Summit White) Join Date: Mar 2021
OP, there is an error with the excel spreadsheet. In PTM "Wet" the first graphic says that steering is in tour, and in PTM "Dry", the graphic says the steering is in Sport. In the spreadsheet, it claims the steering for both is Track. One has to be wrong.
05-18-2021, 06:13 PM | #260 |
But, if you just want to make the A10 car the fastest it will go in a straight line, in terms of both acceleration and speed, how would you set it up, e.g., one mile event,?
'20 ZL1 1LE A10,
05-20-2021, 09:53 AM | #261 | |
I am away from my car still and cannot test, nor verify it for certain. BUT, the graphic and the SS that is below it follow slightly different processes: The graphic explains what will happen if a driver does NOT pre select any Infotainment settings (which lock in steering and exhaust in desired mode REGARDLESS of anything else selected via main steering console display). This means the latter 2 will be driven by what PTM mode one selects. OTOH, the spreadsheet starts the process with a driver pre-selecting a MODE on Infotainment screen. If that is done, steering will stay in that mode (Touring, Sport or Track) regardless of what else is selected in PTM. For example, a lot of folks prefer Touring steering effort for all driving including on track. So, to achieve it, one would lock the steering into Touring on the Infotainment screen. This will make the steering stay there no matter what is selected based on TC button, or PTM mode. So from this perspective, the SS is correct. Hope this explains it. Cheers! |
05-20-2021, 10:05 AM | #262 |
I'm thinking either "sport" mode with competitive mode engaged, or PTM sport 1. Something with some stabilitrack engaged just to keep you straight in case you hit some spilled fluid from a previous cars run.
05-20-2021, 10:17 AM | #263 | |
1. All off and it is up to your talent to manage any tire overslip at a start and then any yaw as the run continues. In other words, no TC at the start and no Stabilitrack are present here and control of the car is 100% up to your skill. Zero nannies to assist ya. 2. Competitive Mode, which eliminates TC so it is up to you to manage any tire overslip at a start as you have full power all the time, but Stabilitrack is present to help manage any excessive yaw if the car gets squirrely during the run. 3. PTM Race, which is a reverse of the above: race level TC will manage and excessive tire overslip at a start by adjusting power for best forward performance, but there is no Stabilitrack to help with any excessive yaw during the run. 4. PTM Sport 1, which includes a slightly more aggressive TC setting so it will intervene during tire overslip more vs PTM Race and Stabilitrack to help manage any excessive yaw. Hope this helps. Btw "yaw" is an angle between where the car is heading vs steering input. So, if the car is heading dead straight and the steering input is dead straight the measured yaw is zero. But, if a car is heading in a different direction vs intended steering input, there will be a yaw value. Such as during cornering, or even a straight run when you hit a bump and the car's balance will be disrupted and to go straight a steering input will be necessary. Stabilitrack measures the yaw and will intervene (by applying brakes at a given wheel) to help a driver bring the car back to balance, if it decides that the yaw is excessive. Without Stabilitrack, it is fully up to a driver to manage such situations (which if left uncorrected may result in a spin). Hope this helps. I am not gonna recommend one over the other, as choosing what nannies to retain is a personal decision. Note that excessive yaw doesn't just happen on road courses. Many a drag racer went into a wall because of it. So, pick the right solution that matches your skill level and your appetite for potential risk. Cheers! |
05-20-2021, 10:19 AM | #264 |
05-20-2021, 12:21 PM | #265 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
superb info here!
05-20-2021, 02:43 PM | #266 |
