01-06-2021, 12:23 PM | #183 |
Drives: 2021 1SS Camaro Join Date: Nov 2018
01-06-2021, 01:44 PM | #184 | |
Drives: like an old lady Join Date: Jun 2012
the article is informative, but little of the information is useful for direct comparison of the engines regarding power. doesn't list primary diameter or length, nor does it mention collector diameter, or the exhaust diameter at all from what i recall.
01-07-2021, 07:52 AM | #185 | |
Drives: 2019 Chevrolet Camaro Join Date: Mar 2020
I just don't think the work involved to swap the cam is worth putting a stock spec cam in. Might as well get an aftermarket cam. If you are worried about having to do valve springs look at the hotcam. |
01-07-2021, 09:15 AM | #186 | |
what remains to be noted is how much more duration is needed to compensate for the lack of cam phasing. my car lost about 15 whp on the dyno playing with the cam timing either direction from factory.
01-15-2021, 03:06 PM | #187 |
Drives: 2021 Camaro LT1 Join Date: Aug 2013
Drives: 2010 Camaro 2SS
Join Date: Aug 2013 Location: Bergenfield, NJ Posts: 33 iTrader Rating: 0 reviews https://www.summitracing.com/parts/ado-12697714 Purchased this and planning on porting it. Should have done si before buying it, but just want to verify, this a genuine LT2 manifold right? ACDelco? Thank you |
01-20-2021, 08:52 AM | #188 | |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- |
01-27-2021, 06:29 PM | #189 |
BLUPRINT_1LE
Those who are interested in what size bolts are needed to fit the C8 LT2 Intake Cover on top of the manifold above. The bolt size is M6 X 1.00 40mm. You can also use the stock bolts that came with the original intake but I chose not to use it.
01-27-2021, 08:13 PM | #190 |
Drives: 2018 Camaro 1SS 1LE Join Date: Dec 2017
Great good to know thanks
2018 Camaro 1SS 1LE w/PDR Summit White
KN intake-MBRP cb- 2nd cat deletes- ACS sides- iroc Z spoiler- Eibach Pro- Katech 95TB- MSD Manifold-GM strut bar- Custom tune by Arun Ahuja @ CCPERF.ca |
01-30-2021, 12:50 PM | #191 |
Can you send a link to where you got these from? Also how many are needed? Thanks
06-07-2021, 01:02 PM | #192 |
Drives: 21 camaro rs/lt1 Join Date: Feb 2021
Hey guys i'm installing the lt2 intake on my 21lt1 camaro. There is a kind of foam isolator under the original one doni put it back because the lt2 intake do not want to sit properly with it
06-07-2021, 02:56 PM | #193 |
Drives: 2018 NFG 2SS 1LE! Join Date: Jul 2018
06-08-2021, 05:49 AM | #194 |
Drives: 2017 SS 1LE Join Date: Mar 2017
Just leave the foam out. Its.for sound.
07-17-2021, 07:57 AM | #195 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
Has anyone established themselves as the go to porters for the LT2? Any members here porting them and a 95MM as a combo? Pray is saying he's not onboard with it as his max effort LT2 with stock TB vs a stock MSD is down 21 peak hp.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
07-17-2021, 11:05 AM | #196 |
Drives: 2020 2SS 1LE Satin Steel Metallic Join Date: May 2020
