04-02-2019, 12:43 AM | #1 |
Drives: 2013 SS Camaro, Black Join Date: Nov 2018
Could I Chip Tune if I install Long Tube Headers (Catted)?
Hello everyone,
My stock cats burnt and I'm looking to install some long headers (catted) from Texas Speed and Performance, but I'm wondering if I could tune with a tuner instead of dyno tuning. Would it be sufficient? And would that pass emissions? I'm conflicted if I should go with the catless because dyno tuning is a bit expensive. If there are cheaper but quality alternatives for long headers please let me know! Best, LL |
04-02-2019, 07:19 AM | #2 |
Drives: '14 BRM 1LE 2SS/RS Join Date: Nov 2017
You sure can. IMO, skip the TSP and go with a Stainless Power Header & SCT Tuner package from RDP and save some coin. Free tunes for life. I made 424hp with that combo and a CAI.
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC |
04-02-2019, 07:33 AM | #3 | |
Drives: 2014 2SS/RS Join Date: Jan 2018
I agree with him.. best bang for the buck is to bundle up your upgrades and get the tune right then.
2014 2SS/RS LS3/M6
04-02-2019, 08:08 AM | #4 |
Started#gottalovethatblue
If you have emissions you'll need cats to pass. As for a tuner, Dynosteve is a forum favorite for remote tunes, but you'll really not be hurting yourself at all with a dyno tune. Besides, with the dyno tune you get to brag about your numbers afterwards.
04-02-2019, 08:34 AM | #5 |
TSP headers are pretty decent for the money. We carry them with plenty of other options. As far as the tuning goes we'd recommend getting on someones dyno when you're ready. You can drive the car without a tune for a bit without hurting anything
04-02-2019, 09:00 AM | #6 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
You definitely should get a tune, but what do you have going on that you burned up the stock cats?
On a 2013, you should not have already had the stock ones go bad. You should look into some diagnostic stuff, because your fueling might be completely off right now.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
04-02-2019, 03:08 PM | #7 | |
04-02-2019, 03:20 PM | #8 |
Thanks for the reply! I would definitely go with that, but I'm kinda short on the pricing.
04-02-2019, 03:27 PM | #9 |
Thanks for the feedback! Is it true you can tune with catless headers to pass emissions? I am from Colorado and some of my friends have done catless and said the altitude affects it enough to pass. IDK could be a myth, kinda new to this.
04-02-2019, 04:05 PM | #10 | |
Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
04-02-2019, 04:29 PM | #11 | |
But on all newer cars, shops mostly just hook up the OBD2 scanner and if you are in all ready states and not reporting codes you'll pass. But I'm still concerned with your stock one going bad so quickly. I would replace the front oxygen sensors while you do headers.
04-02-2019, 07:24 PM | #12 |
Drives: 13' 1LE Join Date: Apr 2012
Yes. Basic tune will do with the headers. Went with a custom Diablo tune at the time and I was satisfied. I recommend Pat G and autocal now! You could run the headers with no tune for some time without any harm. IIRC, sotck tune is on the rich side and Lts will lean it out a bit so youre good to go. I 'felt' 0 power gain from a tune, after headers install.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. Last edited by WHAMMO; 04-02-2019 at 08:24 PM. |
04-03-2019, 12:56 AM | #13 | |
Drives: 2018 2SS M6 Redline Join Date: Oct 2014
Tags |
catless, exhaust, long tube header, tuning |
