03-21-2024, 12:07 AM | #57 | |
Drives: 2011 Chevrolet Camaro SS A/T Join Date: Aug 2022
03-21-2024, 12:10 AM | #58 | |
I added a detailed reply just above, could you please write your opinion )) |
03-21-2024, 03:46 AM | #59 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Why do you have downstream o2's with your cats being removed? In my case I don't have cats either so my downstream o2 sensors are turned off in my tune.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
03-21-2024, 06:37 AM | #60 |
^^^^This.
I don't have cats and my secondary O2's arent even plugged in and the ECM can't even report about them. The fuel trims look normal otherwise. I'd start to question something mechanical allowing enough oil into the combustion chamber to coke the plug but not saturate them.
03-21-2024, 06:45 AM | #61 | |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
OP, do you have notable oil consumption between oil changes?
03-21-2024, 09:05 AM | #62 |
[QUOTE=Diablo4;11413029]Ok, i've checked something again.
Idling 530 rpm Short fuel trim: it varies from -0,8% to -3,2%. Long trim -6.3% Upstream O2s voltage varies from 0,10 to 0,8V. Intake pressure 4,06 psi (0,28 bar) Fuel pressure 57,4 psi (3,96 bar) MAF readings varies 5,2 gramm/sec to 5,5 gramm/sec. I have the second spare one Delphi and the readings were the same. So it seems you're saying these fuel trims are from idle. What are they at cruising? It could easily be different if the tune is off. I'm still leaning towards oil in the intake though.
03-22-2024, 04:23 AM | #63 | |
I will try to disconnect them physically and check for fuel trims again |
03-22-2024, 04:31 AM | #64 | |
[QUOTE=FasNuf;11413110]
Spark plug was mate carbon-growth but it's not an oil, I am sure. What are they at cruising? - I'll check it |
03-22-2024, 06:10 PM | #65 |
Do you have a check engine light for your downstream o2's?
03-22-2024, 09:33 PM | #66 |
03-22-2024, 09:52 PM | #67 |
If your getting those codes that means that your downstream o2 sensors are still turned on in your tune and probably need to be turned off with hp tuners.
03-22-2024, 10:04 PM | #68 | |
It doesnt matter, because the downstream O2 sensors dont affect fueling. They tell the ECU wether the cats are making a change from when the primary sensors control fueling to after the cats process the exhaust. He's getting the code because that portion of the tune wasn't turned off only the CEL. . . . . . .
03-23-2024, 02:53 AM | #69 |
How are you checking your fuel trims? HP Tuners?
