10-27-2016, 04:40 PM | #1 |
New Grille - Photoshop only
I was wandering around dealership waiting on my car. Found myself admiring the grille from the 2017 Camaro SS. I do not know if it can be done but the part is only $78. I figure it is worth a try. Before/After photoshop:
Current: New Grille: Thoughts?? |
10-27-2016, 04:41 PM | #2 |
HTCC Member
I like it , it's different and it fits the Camaro styling just fine.
10-27-2016, 04:41 PM | #3 |
Like Stock look better
10-27-2016, 04:51 PM | #4 |
Drives: 2015 2SS White Convertible CE/INDY Join Date: Mar 2016
What I do like is the consistent design between the top and bottom.
ARH LTH/HFC/Legato muffler, RDP Custom Tune, K&N Blackhawk CAI, Bigworm Blackout kit, ZL1 Rims, Phantom Grills, VMAX PTB
10-27-2016, 05:05 PM | #5 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
Sorry, but the first thing I thought of when I saw it was the grate that holds the charcoals in my old BBQ pit ... like the stock better
10-27-2016, 05:09 PM | #6 |
Drives: 2012 2SSRS Join Date: Jul 2013
Looks too much like my 2016 4Runners grill. But it's all in what you like not us.
Money may not buy happiness, but I'd rather cry in a Chevy than in a Ford!
10-27-2016, 05:16 PM | #7 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2016
Heritage > anything
491 hp/438 tq
LS3 Conversion | Comp Cam Custom Grind | Mast Heads | Comp Cam Push Rods | LS7 Timing Chain | 180 Thermostat | Ported Intake | Ported TB | SLP UDP | K & N CAI | Custom 3800 Stall Converter | Aluminum 1 Piece Driveshaft | Kooks 1 7/8" LTH | High Flow Cats | ARH 3" Exhaust | ARH Mufflers | Eibach Lowering Springs | BMR Floor Brace Subframe Connectors with Tunnel Brace | BMR Moly Lower Rear Control Arms | Oracle LED Halo Kit |
10-27-2016, 06:54 PM | #8 |
Hotchkis Lowering Springs, Pfadt Balance Rear Sway Bar, BMR End Links, Cadillac ATS Front Brembo 4-Piston Brakes, VMAX Ported Throttle Body, VMAX Ice-olator, Volant Cold Air Intake, Magnaflow Resonated X-Pipe, Magnaflow Axle-Back Exhaust, JEGS Exhaust Cutouts, GM Strut Tower Brace, Hurst Comp Shifter, Heritage Front Grill, 3D Carbon Front Air Dam, T-Rex Lower Billet Grill, 3D Carbon Front Vendor Vents, 20x9 OEM Polished RS/SS Wheels Front & Rear
10-28-2016, 07:21 AM | #9 |
Drives: 2018 Charger SRT 392 F8 Green Join Date: Aug 2010
10-28-2016, 07:37 AM | #10 |
Started#gottalovethatblue
I think I'm a +3. Gotta love that heritage grill!
However, if you're wanting to do that grill, please do not put the SS badge like you have it in the picture. Your grill choice isn't a bad one, but putting the badge on the upper side of the grill looks weird. Either put it in the stock location or leave it off IMO.
10-28-2016, 08:42 AM | #11 |
Thank for all the comments, I do appreciate them. I understand all the love for Heritage grille, it is just not for me. It turns out this project will be more - around $130. I can't get the part as advertised for $78 from gmpartsdirect.com. It is highly unlikely I will end up with a nice looking piece after cutting, grinding, glue,plastic weld, etc.
Glad someone else noticed this. It is an annoyance of mine. |
10-28-2016, 09:52 AM | #12 |
Obsessive camaro disorder
Looks like expanded metal
**2010 2ss/rs**
10-28-2016, 10:14 AM | #13 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
I was considering the heritage for a while... but I fell in love with the ZL1 version. When I did the conversion, I absolutely had to have it. Looks more modern to me and looks great imo.
OP, that is definitely different and I personally like it, but I still like the ZL1 version so much more. |
10-28-2016, 12:10 PM | #14 |
I would put that pattern grille in the heritage grille shell.
Then it'll look right.
2015 Camaro 1LE
2009 Challenger R/T 2007 Solstice GXP 2004 Colorado ZQ8 2002 Trans Am WS6 Collector Edition 1999 Blazer 1994 Grand Prix SE B4U |
