11-16-2018, 09:46 PM | #1 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
My racestar wheels won’t go on the car?!
Straight to the point,
I ordered 17s for rear and 18s for front. I got the lug juts from racestar, they are wrapped in 305 45 r 17 in rear and 26 6 18 in front. The front wheels go on just fine with the wheel centric hub and washers with provided lug buts. Did the same for rear but for some strange reason they all just won’t align correctly or something because when I think they are alll right I turn very gently with the ratchet before putting car on ground and they start to spin freely once again. Have tried just about everything. And I’m lost... any ideas? I put my stock setup back on the car right now.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
11-17-2018, 07:22 AM | #2 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
I put mine on for the first time yesterday and struggled with one wheel as it wasn't lined up correctly and I had the same spinning lug nut problem. Pulled it off and reattached and it went on fine the second time. I was laying on the ground working off my back and it was not the easiest thing to, especially for a senior citizen like me.
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ |
11-17-2018, 09:06 AM | #3 |
I don't run the hub rings on the rear. The shank lug nuts line up the wheel perfectly and really not needed. I do run them on the front. I've had mine off and on at least a dozen times with no issues.
11-17-2018, 12:08 PM | #4 |
Do you feel vibration without having those hub rings?
11-17-2018, 12:09 PM | #5 | |
11-17-2018, 12:24 PM | #6 | |
11-17-2018, 03:02 PM | #7 |
Drives: 2018 1SS Join Date: May 2015
After reading this I took one of my race stars out of the box ( 17x10.50 ), I see no hub centric rings ? I'm thinking i'm missing something here , so I pulled one rear wheel off my car and put the race star on .. It fit fine and bolted down fine with the stock lug nuts .. So I guess mine don't use hub centric rings ?
11-17-2018, 09:06 PM | #8 | |
11-17-2018, 09:56 PM | #9 |
No I did not get a lug kit .. I just used my factory lugs and they worked fine ..The wheels I got had a tapered seat just like the factory wheels .. Maybe your uses a different lug like the shank style ?
11-17-2018, 10:40 PM | #10 |
Drives: 19 SS 1LE Join Date: Nov 2018
try the rear hub ring on its own, it might be the wrong size for the rear hub. If it works without it installed thats likely the problem. I don't know these cars, but my S2000 had different front and rear hub sizes to prevent techs from installing fronts on back and backs on front.
11-18-2018, 06:09 AM | #11 |
I have no vibration at almost 140 mph trap speeds.
11-18-2018, 06:58 AM | #12 |
Drives: 2017 1SS A8 Nightfall Gray Join Date: Feb 2017
The first few times is a real PITA its almost like the shanks on the lugnuts have too much plating on them once you take em on n off a few times it gets better, on mine without the rings on it feels like the back tires are out of round not a big deal on the 1/4 mile , but gets on my nerves on the street so I use the rings , have patience don't strip your studs maybe a better quality lugnut would make it easier
11-18-2018, 07:59 AM | #13 |
Thanks everyone, yes I have the shank lugs. No way I could have used the factory ones. With that being said I had brought the car to discount tire and they were successful with NO ISSUES in getting them installed. Maybe I should of just used my power tools on them, seemed to be the trick on there end. Nonetheless I appreciate you alls help. FYI on the way home my stock wheels were being brought home with me by my dad in his truck and I’m thinking the car was stuck reading those sensors or something because my dash lit up like a Christmas tree. Every light related to the wheels were going off so I unplugged the battery, put away the stock wheels so they are no where near the car and once I started the car up all was well. I did notice right before this happened the car was reading the tire pressure on the tires but after this I just get lines with them lighting up green. Very strange but whatever car runs and HOOKS like no other.
11-18-2018, 09:01 AM | #14 |
I had a warning when I drove to the track yesterday and car went into limp mode until I turned off TC. I had no tire pressure warning until I arrived at the track and lowered the tire pressure and then that light went off. Just held TC down for several seconds until all nannies turned off.
