06-04-2019, 05:38 PM | #1 |
Drives: 2016 camaro 2ss Join Date: Nov 2016
Qa1 cf driveshaft
Anyone have the qa1 cf driveshaft if so how are you liking it? Any problems with it?
06-04-2019, 06:43 PM | #2 |
Drives: 1987 Z28, 385cid, '16 Camaro 1SS Join Date: Feb 2016
There've been multiple issues with the carbon fiber driveshaft. I know of at least half a dozen that have broken. The aluminum driveshaft is the way to go.
02/23/16: 1100, 03/16/16: 2500 # TGHR6N
03/16/16: 2500, 03/18/16: 3000 TPW : 4/11/16 04/8/16: built & VIN 04/11/16 - 04/28/26 : 4B00 Bayed QC hold, 04/29/16 : 4200 Rail yard '16 1SS 6M, black with jet black interior, split spoke gray machined faced wheels, and black front/rear bowtie emblems. |
06-04-2019, 08:07 PM | #3 |
I know at least one car here is running in the 10’s with it. Believe the CF shaft problems were a different brand, but hopefully someone else who knows the situation better will chime in.
06-04-2019, 08:23 PM | #4 |
Drives: 2017 1SS A8 Nightfall Gray Join Date: Feb 2017
I just put a QA1 in my car Friday ran 10.26 with a 1.46 60 ft Saturday seems good n smooth no vibrations or anything , I do know a big name Aluminum one broke on a dyno that's why I went with the QA1
06-04-2019, 09:03 PM | #5 |
Drives: SS 6 speed of course Join Date: Jan 2016
Went with the GM performance ZL1 type for the SS, there are many advantages to a two piece shaft.
06-05-2019, 07:32 AM | #6 |
I look at it like more pieces to break and more weight , my understanding is the newer cars have 2 piece shafts because not enough room with the small tunnels for a large enough diameter shaft to get the smoothness the factory wants.
06-05-2019, 07:55 AM | #7 | |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
A good quality CF 1-piece is the way to go as long as the person can afford it.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
06-05-2019, 11:16 AM | #8 | |
1) NEVER happen with a the ZL1 driveshaft as it is stronger than the curb... 2) The carbon fiber could just shatter next time under load, 3) the aluminum could dent leading to vibration or critical failure later on. I have NO opinion on a race car. Aluminum in specific. I don't like them B) two piece does NOT have high speed instability. Two piece design does not suffer from vibration issues at high speed, all one piece designs are suspect, even more critical if not perfectly installed. C) I believe the factory shaft is 3 lbs heavier than the Aluminum shaft., the middle bearing of the two piece shat is kind of like a driveshaft safety loop.. (more than 3 lbs.). Sure one is rotational on is static, not like 1 and 3/4 radii is a huge consumer of HP. I'd counter the factory shaft has less diameter which and we all know that rotational inertia is mass times radii squared, so radii is about 4x more important than weight. For me the ZL1 drive shaft just made more sense. Ever heard of one broken and / or ANY high speed racing problems such as vibration?
06-05-2019, 02:48 PM | #9 |
Drives: 18 1SS 1LE HyperBlue Join Date: Aug 2018
I can say that I have been to their place and seen them make the driveshafts and it is nothing but top notch how they do it and the equipment they use.
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
06-05-2019, 04:37 PM | #10 |
My thinking was if a CF shaft does shatter that should not hit the underneath of the car hard enough to set the air bags off like the others have been know to do I've shot enough CF arrows over the years and they just splinter and colaspe ,I would think DS would be like that, yes something could fly up off the road and screw up a CF shaft but damn that exhaust protects it alot , I will say this its not as light as you would think. On my cheap bathroom scale it was less than 3lbs vs stock DS . This may be just in my head but I think the car reacts quicker.
06-05-2019, 04:53 PM | #11 |
Agree that if the shaft breaks, I like carbon fiber. I have never heard of a ZL1 shaft breaking... so for a true street car that needs a shaft, I went with the GM performance shaft, basically a ZL1 shaft that bolts into the SS. As stated above I would not consider an aluminum shaft because if it breaks (and they do), you could be in REAL trouble.
Don't know what to say about the response or drivability? Rotational momentum is related to the square of radii, and this is 1 and 3/4 inch... not much. compared to say a 29" diameter tire. About 55X more important.' From GForces's site: "The 3.5” or 4" aluminum driveshaft is rated to 900hp and speeds up to around 160 mph with no issues or vibrations. As they say “smooth as glass” at 160 mph." I'm looking at this or even more HP and even though I don't drive 160 MPH, my car is capable of such. Once again I'll point to that I know of no ZL1 driveshaft issues (not including convertible).
06-05-2019, 06:03 PM | #12 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
Damn I thought it would be a better savings than that too. I would think if an ATI UD pulley helps then this would help it spin up a little faster as well?? But agree DS seems protected enough by exhaust. Hmmm
06-07-2019, 06:25 AM | #13 | |
As far as quality of a CF shaft, remember that member toohighpsi had one break on his SECOND pass at the dragstrip. Have not been hearing this about the ZL1 shaft. |
06-07-2019, 07:17 AM | #14 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
How much less does the GM Perf ZL1 shaft weigh than a SS? How much are they?
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
