05-25-2019, 07:23 PM | #1 |
Drives: '17 1ss Join Date: Jun 2017
Fbo 1le 530/495
Been doing alot of testing with my '17 1le with the hi ram. Added a ati ud pulley and speed density tune from Dave Krysienski @ EFX tuning and some minor modifications on the hi ram since last i was on the dyno. Unfortunately i didnt get a baseline when my car was stock on this dyno. Final numbers are 530/495. Now to get to the track...timeslip coming soon!
Mod list - My ported holley hi ram/95mm tb E85 Speed engineering 1 7/8ths headers Speed density tune by Dave Krysienski Velocity stack on hi ram Ati ud pulley https://youtu.be/qLL20wdFVXE |
05-26-2019, 05:09 PM | #2 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
That’s bad ass.
Have you seen how much power drops with heat soak with the aluminum manifold ? I’m guessing this pull was not heat soaked |
05-26-2019, 10:09 PM | #3 |
I havent but it definately holds some heat!
05-26-2019, 11:55 PM | #4 |
no fuel system mods? how many milliseconds are the injectors open?
05-27-2019, 05:22 AM | #5 |
Stock fuel system. No idea on the injectors thats all the Dave's deptartment
05-27-2019, 04:01 PM | #6 |
Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
Stout numbers sir, looking forward to seeing them timeslips.
Their is still quite a bit of pump and injector window left at that power level.
05-27-2019, 07:15 PM | #7 |
NA can go a long way on the stock fuel system being the fueling demands are much less then FI.
2016 NFG 1SS A8
05-27-2019, 07:38 PM | #8 |
Drives: 2019 Camaro ZL1 M6 Join Date: Nov 2018
So uh, are these numbers really high or am I missing the mods that are adding almost 130whp over stock?
I ask because I think I need all these things. |
05-28-2019, 02:41 AM | #9 |
Drives: like an old lady Join Date: Jun 2012
yeah let’s see some weight and trap speeds. badass that the stock cam cooperates above 6500. stock valvespring?
05-28-2019, 07:27 AM | #10 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
stock cam? how do you like the high ram?
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
05-28-2019, 07:41 AM | #11 |
The limiting factor for power range on these engines is not the valvetrain, it's the shitty stock intake manifold. Thanks to the C7 the 6th gen had to suffer as well. With VVT, we can still make good use of the added rpm the high ram adds.
2016 NFG 1SS A8
05-28-2019, 07:47 AM | #12 |
Drives: 2016 Camaro SS Join Date: Sep 2018
With no baseline you can't even really say anything about the numbers either way, it could be a super happy dyno and started at 430 rwhp. Trap speeds will tell the tale.
05-28-2019, 08:45 AM | #13 |
Dynojet sae corrected is usually pretty accurate at most places. But I guess you never know
I’ve seen other hi ram bolt on cars over 500 too. One of PRAY’s cars did 505 with an a8 still in 5th gear. |
05-28-2019, 10:45 AM | #14 |
Yes stock cam and stock valve springs. Ive been 124.8mph in 5k da. Well see in a few weeks what it does all out now. Ill be doing some 1/8th mile testing this weekend. As cast hi ram did 497/471 on this same dyno
Thread Tools | |
