06-21-2023, 11:29 AM | #1 |
Drives: 18 ZLE, 18 SS1LE, 16 SS, 23 ZL1 Join Date: Jan 2021
De-tuning the LT4
Odd title, I know
I’m planning on taking my car to a NASA club event soon where there is a 103db sound limit at 50ft. My car has headers, intake, ethanol, cam, 9.25” lower pulley and 3” Borla S-type NPP. I have Gesi 2 HO cats that have V-band clamps at each end and can be swapped for delete pipes. I usually run the delete pipes at the track. I’m not only concerned about exceeding the noise limit but also when I run slicks on E60 the clutch seems to slip in lower gears under hard acceleration. Dyno numbers on E is 706 hp/745tq. The hp/tq gains are nice, but not necessary to run a good lap on the track. My thought is this: Remove 9.25” pulley and run stock size pulley. Leave cats on for sound reduction. With reduced boost and cooler ethanol temps cats might survive one track day. Running at Sonoma so should be cool weather. Thoughts? |
06-21-2023, 11:54 AM | #2 |
Who Needs to KNOW?
Turn down aimed away from mic location ?
ing for grip.
06-21-2023, 12:01 PM | #3 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
Get some Laguna pipes made like I made.
06-21-2023, 12:18 PM | #4 |
06-21-2023, 12:35 PM | #5 |
Drives: 2023 ZLE M6 Join Date: Jun 2022
If a clutch is slipping it will start in the higher gears, not the lower gears, since there is more load on it. Are you sure it's not wheelspin or TC/PTM settings?
2023 ZLE M6 Borla S-Type Catback | Rotofab CAI | Soler TB | MPI Lid |
06-21-2023, 01:28 PM | #6 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Based on your mods, your car should be just about identical to mine dB wise. I have some slip-in baffles that I picked up at the NCM track after getting black balled for sound at the last Camarofest. They slip right in and attach with one sheet metal screw. They got me under the 98 dB limit at NCM and at Atlanta Motorsports Park.
I'm running a ZL1 clutch in my SS and making slightly more power than you with no issues. As others have speculated, I believe you may be breaking traction a bit in the lower gears.
Baby Blue
06-21-2023, 03:01 PM | #7 | |
Also you sure it's your clutch slipping? |
06-21-2023, 07:45 PM | #8 |
Drives: 2023 ZL1 A10 Join Date: Nov 2021
You just did a new clutch , in you other thread. Have fun , Safe travels.
2023 ZL1 A10 Shadow Gray Metallic
06-21-2023, 08:30 PM | #9 |
Smoothboost FTW. Need less power, turn the knob down. Need to murder the Hellcat in the other lane, turn the knob back up. Easy peasy.
06-21-2023, 09:41 PM | #10 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
I'd just return the blower back to stock specs.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE Last edited by AZ_1LE; 06-21-2023 at 09:52 PM. |
06-22-2023, 05:52 PM | #11 |
Drives: 2022 ZL1 M6 Join Date: Mar 2022
Least hassle seems to be getting some Laguna pipes. Easy on and off without worrying about taking a belt off or having to deal with the tune. I'd go with the simplest option personally.
2022 Black ZL1 M6
RF intake, Soler TB & TC, ADM v2 reservoir, AWE Touring non-resonated catback exhaust. 535 whp, 537 tq. SAE Smoothing: 5. DynoJet. No tune. 91 octane. |
