Old 05-20-2016, 07:00 PM   #1
k818mn1
Drives: 2016 Camaro SS, Garnet Red
How to use 5th Gen cargo net on 6th Gen
I kept my cargo net from my 2013 SS when I traded it in, expecting it would fit my new 2016 SS.
In fact, of course, the 6th Gen cargo net is totally different, much smaller, and $50.
So I figured out a way to still use my old cargo net.
First buy four cargo net nuts, GM part number 11561145. I found them on eBay, four for $19 shipped.
You will also need two bolts, say one inch long or so that fit the screw thread on the cargo nuts. I had some lying around, but home depot will have them.
Then remove the four existing nuts from the rear trunk liner and pull it out. Remove the pushpin from the side trunk liner and pull it to one side to reveal the supporting bracket. Install a bolt through the bracket. I superglued it, but you could put a nut on it.
Put the liner back in place and screw the cargo nut onto the bolt. You might want to use shorter bolts than i did so they don't show!
Repeat on the other side.
Then reinstall the rear trunk liner with the original nuts at the bottom but use the two remaining cargo nuts for the top.
Fit the 5th gen cargo net as shown below.
The bottom is not secured to anything, but it seems to work fine.
Sent from my XT1095 using Tapatalk
k818mn1 is offline   Reply With Quote
Old 05-21-2016, 09:32 AM   #2
chris227
chris227's Avatar
Drives: 2020 Camaro 2SS
Thanks for the idea and pics. great idea.
Old 05-21-2016, 10:09 AM   #3
NEGXXIS
NEGXXIS's Avatar
Drives: 2019 Camaro SS A10
Awesome... thanks!!!
2020 Range Rover Sport HSE P525 Supercharged 5.0 - Firenze Red - 9012 wheels
SOLD 2019 Camaro SS -Wrapped in Matte Magnectic Black - Anderson Carbon Hood and Rear Spoiler – Ikon front spoiler – OEM ZL1 Side Rockers - ZL1 Addons Diffuser - BMR 1.0” Lowering Springs - MRR 228 Wheels 20x10 and 20x11
RIP 2016 Camaro SS https://www.camaro6.com/forums/showthread.php?t=565453
SOLD 2010 Camaro SS Featured in GM High Tech Performance and Camaro Now Magazines - http://www.superchevy.com/features/g...of-perfection/
NEGXXIS is offline   Reply With Quote
Old 10-06-2017, 08:56 PM   #4
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
i did the same but different with a 5th gen net. works great.
Old 10-06-2017, 08:58 PM   #5
JCunningham
Drives: 2017 2SS M6
