12-19-2021, 08:36 PM | #1 |
Drives: 2016 Camaro SS 2017 Yukon Denali Join Date: Jan 2020
LT1 aftermarket pistons
Does anyone make a 4032 piston for the 6.2? All I’m seeing are 2618. I need a 4.060 bore 11.5cr piston for a stock rod and L8t crank in 4032 for a mild na 6.6 build.
12-20-2021, 07:15 AM | #2 | |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
I don’t see what you are looking for. Correct if I am wrong but that size your looking for I have seen in Mopar products not GM builds.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 12-20-2021 at 08:08 AM. |
12-20-2021, 05:01 PM | #3 | |
My bad, I did mean 4.065 bore. It looks like diamonds entire lt catalog is 2618 though. |
12-20-2021, 05:19 PM | #4 | |
Straight off my box. These are the ones you want for a NA build. I did manley rods, reinforce your heads big time and really go with a bigger cam if your doing these.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
12-21-2021, 12:21 AM | #5 |
Drives: like an old lady Join Date: Jun 2012
i plan on using a dome piston. je, wiseco & diamond all offer domes w/ .200 reliefs that bump compression to 12.3 with a factory cc head. i'm hoping to be around 13:1 with aftermarket heads and thinner gasket. otherwise there's no point in swapping pistons for an na build, imho.
12-21-2021, 12:41 AM | #6 | |
The fact that reduce weight, and improve strength, durability and ring sealing will help any build with better quality pistons. There’s nothing wrong with someone adding quality pistons to NA build to make it bullet proof and down the road to add a power additive. It’s a costly move but if anyone has the money to do that then I say go for it.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 12-21-2021 at 03:47 AM. |
12-30-2021, 06:34 PM | #7 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
What benefit are you looking for in the 4032 grade? I thought most "regular" type automotive pistons were high silicone?
12-30-2021, 06:37 PM | #8 | |
12-30-2021, 07:17 PM | #9 | |
https://m.youtube.com/watch?v=5Nm5hNbtfoY https://www.holley.com/blog/post/eve...n_v_lt_engine/
12-31-2021, 08:13 PM | #10 | |
2618 is low silicon. This makes the material more resistant to fractures, but also is softer and requires more bore clearance due to its higher coefficient of expansion. The softness is somewhat alleviated with skirt coatings and ring land anodizing, but they still rattle at cold start and won’t last. 4032 is high silicon, and is more brittle than 2618, but wears better and expands less. 2618 is typically used in power adder applications and 4032 in na. The trade offs for the “toughness” of 2618 are not worth it for what I want to do. A hyper eutectic cast piston like the OEM would work for me. |
01-01-2022, 09:46 AM | #11 |
I did the Manley Forged Pistons and Rods. I did their blower setup with 10.0 compression.
01-02-2022, 07:36 AM | #12 |
you might look into what it takes to hang a stock rod on an aftermarket piston, it may be cheaper or within a couple hundred bucks to use an aftermarket rod, as well. arp fastener requires big end resizing and possibly the wrist pin needs bored.
why are you wanting a forged piston for a "mild" na build? i don't see any aftermarket stuff outperforming a stock piston in that instance. esp if you are planning on keeping the compression so low. id be looking to see what it takes to use a stock LT1 piston in your case.
01-02-2022, 12:28 PM | #13 | |
There are plenty of 4032 offerings from mahle and others for the 3.780 bore engines that use the stock rod. The stock rods are stronger than most people give them credit for. Not sure how 11.5 is low comp, but then again I remember when 9.5 was the top end for a pump gas build. |
01-02-2022, 01:26 PM | #14 |
So is there any improvements we can make by going to a piston with a high expansion coefficient to get better properties to resist cylinder pressure and/or mass reduction? I would think there would be more custom designed alloys for engine piston use but maybe these are. I would sacrifice cold start piston slap noise for better properties.
