TireRack
Old 01-05-2022, 11:15 PM   #1
jesse121pm
jesse121pm's Avatar
Drives: 2012 Camaro 2ss 45th anniversary
Code p2122 & c0242
Name:  Car Codes.png
Size:  87.0 KBI was driving my 2012 camaro ss just doing normal driving and code p2122 & c0242 threw a check engine light and said Engine power reduced and service stabilitrak. I saw that this is common but I shut the car off popped the hood and unplugged the throttle body, and plugged it back in. It still had the check engine light but the reduced engine power and service stabilitrak went away. I cleared the codes because I had my scanner on me luckily. It has ran normal since then but I don't know if I should take it to the dealer. Or should I try cleaning the throttle body. I just installed my oil catch can 2 weeks ago. Here is the screen shot and now the codes still have not came back. Please help.
jesse121pm is offline   Reply With Quote
Old 01-06-2022, 12:55 AM   #2
dru21281
Recently dealt with P2135 on my car and also put it into limp mode. Started happening occasionally and would clear and run fine fir a bit. Eventually became undrivable as limp mode wouldn't clear.
Ended up being the accelerator pedal. Ordered a new OEM pedal which came defective and gave same problems. Had to order another used pedal and it's working great now.
Sent from my Pixel 2 XL using Tapatalk
dru21281 is offline   Reply With Quote
Old 01-07-2022, 08:33 PM   #3
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
Replace the app.....gas pedal.
NOT A 45 is offline   Reply With Quote
Old 01-08-2022, 08:59 PM   #4
jesse121pm
jesse121pm's Avatar
I figured it was the gas pedal. But what is the app?
code p2122
