Old 12-29-2019, 07:06 PM   #1
that_zl1_1le
Drives: Chevy zl1 1le
18 inch track rims and square tire setup
Hey all,
Wanted to get a few options about down sizing rim to 18inch for track and running a square tire setup for extended tire life on track. Planning on running 100TW tires.
What setups do you guys run as 18 inch and if you guys are seeing any issues with square setup.
Thanks all
that_zl1_1le is offline   Reply With Quote
Old 12-30-2019, 11:08 AM   #2
Roostie
all it takes is cash
Roostie's Avatar
Drives: 2018 LS V6 1LE; E350 wagon; Model3
You should include what kind of tires you plan to run: slicks, Hoosiers, or street tires in 60, 100 or 200 TW. I'd edit your original post to add that info.
Roostie is offline   Reply With Quote
Old 12-30-2019, 11:30 PM   #3
that_zl1_1le
Noted. Thanks
Old 12-31-2019, 09:12 AM   #4
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
I doubt you are going to find a better 100tw tire than your stock G3Rs. If that's your intention you are just wasting money. However 18s for slicks is worth it all day.
Old 12-31-2019, 11:23 PM   #5
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
I am not entirely sure this car would benefit from a true square set up. You would have to run a huge spacer up front to get a wheel to clear that would be remotely similar in size to the rear.
After spending lots of time going through different wheels and tires, I have settled on the stock G3R's as the best all around track day tire.
With that said, I have had stellar results with my current Nankangs in 315/30/18 on 18x11/18x12 wheels. No lap time comparisons, but the car feels good on them.
seanblurr is offline   Reply With Quote
Old 01-01-2020, 11:10 PM   #6
that_zl1_1le
Yes I have heard the stock G3R is hard to beat as a grippy tire. I been hearing tire wear is not so hot. Expected? Yes. But if I down size to 18’s and match them with the right tires I might get more enjoyment(seat time) and don’t have to replace tires so often.
Thanks Sean. I would love to see the setup in person since it looks like we are both in NorCal. With your Nankangs are they different sizes front and rear? or 315/30/18 square? Do you have any issues with the LSD or TC withe the smaller size?
Old 01-02-2020, 12:52 PM   #7
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
I have experienced some weird issues, but I can't pin point them to the wheels. Last event, with TC fully off, the car seemed to be fine. I had to run it completely off, though, or else the TC would engage far too often.
Old 01-02-2020, 01:39 PM   #8
rotis
rotis's Avatar
Drives: 2019 ZL1 1LE
With a square setup the car sees a constant 1.8% rear wheel slip. It stands to reason that it would engage Stabilitrack/TC earlier and more often as a result.
rotis is offline   Reply With Quote
Old 01-03-2020, 08:30 AM   #9
TrackClub
TrackClub's Avatar
Originally Posted by that_zl1_1le View Post
Hey all,
Thanks all
Seems that G3Rs (or Hoosiers) are the way to go for ultimate pace with longevity being the price.
If your priority is fun AND longevity then consider G3s as they now come in stock ZL1 1LE sizes. This is an SS 1LE and regular ZL1 tire and it is very close, if not equal to some 100 tread rated tires. The price point is hard to beat and longevity is decent at 6-7+ days. IMO these are the best bang for the money, bar none (i have also tried Cup2s and RE71Rs).
Other than that, there are no miracles and speed costs
