09-02-2023, 06:15 PM | #1 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
ZL1 - NON-E Wheel Cleaning
I have zero interest in changing out the pads so leave that at the door.
I have zero problem cleaning them with a cloth but I am looking for a "quicker" yet safe solution to cleaning the wheels Any opinion on this? Another product? https://www.amazon.com/Adams-Wheel-S...f_=as_li_ss_tl
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
09-02-2023, 06:45 PM | #2 |
Long hauler
I had something similar when I had my LT with the 4 Piston front, it worked really well for about 3/4 of the first wheel.
The dust gets gummed up on it, need some type of filter to scrub against (like the 2 bucket wash method) I think for ideal outcome
2016 1LT v6 - Totaled Happiness: Infinite |
09-02-2023, 07:22 PM | #3 |
376 cubic inches of fun
I just use my Turtle Wax one step car wash and wax on the wheels after the rest of the car is washed and rinsed. The ZL1 wheels have some tough to reach spots; I use a thin sponge to get behind the spokes, and since those don't get everything, I follow up with my pinky fingers (in rubber gloves).
It's an intimate experience! |
09-02-2023, 07:23 PM | #4 | |
09-02-2023, 07:47 PM | #5 | |
https://adamspolishes.com/collection...l-wheel-woolie
09-02-2023, 08:05 PM | #6 |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
I hose rinse my car then use a foamer from pressure washer to put really thick foam soap layer on entire car and wheels and let it soak in (I do not pressure rinse/spray the car of course) Then after bucket washing car with microfiber mits etc, I use a basic long-handle soft bristle plastic wheel brush with soap on my wheels and go over each one in a couple of passes on spokes and around outside edge, and then I filtered-hose rinse the whole car and wheels and here's the key for me...
I don't worry about the wheels getting perfectly clean and shiny, I don't put much effort into scrubbing nooks and crannies, I never wax wheels. They're just wheels to me and on my ZLE they're satin black (which helps hide dirt and dust), but IMO dust looks ok and shows you're driving the car hard. |
09-02-2023, 08:05 PM | #7 |
Yes Fran those wheels are a pain in the butt to clean! When I do clean mine which is not very often, I need to find an easier way to do it.
09-02-2023, 09:30 PM | #8 |
Drives: Sharkskin Metallic ZL1 Join Date: Mar 2023
I use these.
bzczh Metal Free Soft Wheel Cleaner Brush, Synthetic Wool Rim Cleaning Brush, Highly Water Absorption, Dense and Durable Tire Brush for Cleaning Wheels, Rims, Spokes, Fenders, Engines… https://a.co/d/0kVqnQd |
09-03-2023, 06:52 AM | #9 |
Drives: 2022 Camaro ZL1 Join Date: Dec 2021
To clean the spokes and outer area, I use a brush like this. Works great on my ZL1 wheels. Super fast and easy.
https://www.unionjacktools.com/9-sof...l-brush/?gad=1 Of course to clean the barrels, you'll need a different brush.
Randy in Nashville
2022 Chevrolet Camaro ZL1 A10 2020 Ford Mustang Shelby GT500 2020 Genesis G90 Ultimate 2019 Mercedes-Benz SL450 2017 Corvette Grand Sport A8 2024 Honda Civic Touring 1971 Datsun 240Z |
09-03-2023, 07:22 AM | #10 |
Use a good power washer with Dove soap, and if you
Don’t want to do this every fill up, change pads! I use EBC reds, after break in, much improvement! |
09-03-2023, 07:44 AM | #11 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
I actually use these in combination with a dedicated wash mitt.
https://www.amazon.com/Boars-Hair-Ul...zcF9hdGY&psc=1 Then I use turtle wax graphene spray to give them a little resistance to the future brake dust. This allows washing the dust off in the future to be a bit easier. Then the next few times I wash the car I just use wheel cleaner and my pressure washer( 2000 PSI with 45 degree tip). I have one of the few electric pressure washers from Greenworks that actually has the PSI advertised. Works much better than the ones you can find on Amazon. Unless they started selling Greenworks recently. |
09-03-2023, 08:18 AM | #12 |
Old Gearhead
Drives: 2023 GMC Sierra Denali Ultimate Join Date: Nov 2018
I've been using foaming window cleaner on mine after every drive. If I keep the car I'm swapping the pads....
2023 Camaro ZL1 convertible - black - SOLD
2023 GMC Sierra Denali Ultimate - black |
09-03-2023, 11:40 AM | #13 |
Thank you Al Oppenheiser!
ShowCarNerd(TM) reporting in...
Skip it for three reasons. 1) It's too big in diameter to get behind the calipers and between the narrow spokes, 2) it's too stiff and coarse and might swirl the paint, and 3) the handle and brush are too short to reach the entire wheel barrel (front or back).
I have a set of wheel woolies, which are only used on the barrels. The skinny wooly brush is needed to get behind the calipers and the fat elsewhere. $50 is a lot of money for cleaning barrels, but if you want to clean these deep barrels relatively easily and quickly on the ground, they are hard to beat. I'm not worried about swirls in the barrels. I use a Chemical Guys Gerbil brush for the spokes and front grille. The gerbil brush is small enough and soft enough that it can go where needed and not scratch anything. I use one of these detail brushes for the lug nuts. For coatings, all my wheels are ceramic coated (Gtechniq Crystal Serum Black) and hydrophobic coated (Gtechniq EXO v3). I use a custom mix of Carpro Reload, Ech20 and distilled water as a quick detailer on the car and wheels. Hydrophobic coatings will reduce the amount of brake dust that collects on the wheels, as well as make them much easier to clean. You do not want a greasy residue from detail spray on the wheels or it will attract more dust, not less. For wash soap, Adams Car Shampoo and Carpro Reset are both good, neutral-pH cleaners that are excellent at lifting dirt and road oils/grease off the paint while maintaining high lubricity to mitigate swirling. Full disclosure: I also swapped pads to Powerstop Z26. |
09-03-2023, 02:50 PM | #14 | ||
I made 2 videos on cleaning my 1LE wheels. one with a hose the other rinseless washing
2022 1SS 1LE 6M in Riverside blue
Found exact build local- ETA 7/31/22 New ETA - 7/26, 7/30, 7/31, 8/1, 8/8, 8/15, 8/21, 8/28, 9/17 8/24. IT HAS ARRIVED at the dealer 8/25- It is in the Garage ACS ZL1 Sideskirts, 20% tint, CAI Intake |
