04-21-2016, 05:18 PM | #15 | |
Drives: 2SS, Hyper Blue Join Date: Feb 2016
??...Um...From GM: And rather than a traditional front air dam to reduce aerodynamic lift, the team developed a flush belly pan that stretches from the front grille to the center of the vehicle. Paired with small “spats” forward of the front tires, the smooth underbody helps reduce total lift by 30 percent – while also reducing aerodynamic drag. http://media.chevrolet.com/media/us/...ro-teaser.html
Steve
Hyper Blue 2SS, 6M, NPP, Sunroof, Nav |
04-21-2016, 05:23 PM | #16 | |
Retired from Car mfrs....
Absolutely, i know they do something, but it more important for me to have a clean look and use my ramps than have the reduction "in lift" - and thats what makes life great, its your car, do what makes you happy! |
04-21-2016, 06:03 PM | #17 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
Similar to what the current ZL1 has, I'm sure that is where it came from. Aero benefit for sure to redirect air ... If you're tracking it ;o)
I have them and I use race ramps instead of the Rhino ramps... -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
04-21-2016, 06:08 PM | #18 | |
Besides, I have a lift so NO ramp gyrations....
Steve
04-21-2016, 06:16 PM | #19 |
PC Technician
Drives: 2016 Hyper Blue 2SS Join Date: May 2012
Is there any ramps that will clear them easily? I don't any ramps yet and I'm in the market to start doing my own oil changes after my first two.
04-21-2016, 06:18 PM | #20 |
Drives: camaro Join Date: May 2013
I lost about 8 mpg when I removed them. So back on they went
Hyperblue/JetBlack |
04-21-2016, 06:23 PM | #21 | |
I used to be Dragoneye...
vital? Well...they're bound to hit things and get eaten up, which why they're made of rubber. |
07-04-2016, 12:17 PM | #22 |
Drives: 2LT/RS v2.0 & 2016 2SS Join Date: Jul 2013
wondering if anybody here is willing to part ways with their rubber air deflector? looking for one... have a project in mind...
07-05-2016, 04:41 PM | #23 |
Drives: 2020 rally green rs Join Date: Oct 2013
They may just deflect something in the road like a tree branch or something I'm leaving mine on, you can barely see them.
07-05-2016, 04:52 PM | #24 |
Drives: 2016 Camaro SS1 Join Date: Mar 2016
LOL!!! Thanks! didn't even know they there
07-06-2016, 10:43 AM | #25 |
Drives: 2016 SS M6, NPP Join Date: Apr 2016
My left one is kind of beat up from a steep driveway.. checked to see how much it cost, it was $80 :/
07-06-2016, 12:25 PM | #26 | |
Drives: Beater Honda Civic Join Date: Jun 2016
My daily beater is lowered and can't use normal ramps. I used several 2x10s to build ramps. The bottom board is 6', the next is 4.5', the next is 3', then a 1.5' board. Add a small stop on the top and it's good to go. Add a couple strips of rubber underneath if they are used on smooth pavement to keep them from sliding. They are heavy, but I find they work better than any other modestly priced ramp I've tried, and they are stout enough to drive full-size trucks on. As for the original question, airflow around your tires/wheels accounts for a disproportionate amount of the overall drag of your car. Small improvements here can make noticeable changes in drag. Removing the spats will likely worsen fuel economy, but unless you pay very close attention to it, you probably won't notice (probably ~0.5mpg). |
07-06-2016, 02:25 PM | #27 |
Drives: 2016 2SS Garnet Red Camaro Join Date: Aug 2015
They're functional and mine are staying where they are unless they're torn off. Chevrolet has used them on Corvettes for several years. Do you really think Chevrolet just added them for "grins"? Why doesn't anyone asks an expert at GM or Chevrolet for the reasoning behind them.
Or perhaps you can trust this statement, "They're made for speeds exceeding 125 mph". Or some such off the wall comment made by a forum member on this thread.
Ordered: 8/8/15, 2SS Garnet Red
Built: 10/14/15 Current: Took Delivery, 12/24/15 Added Procharger supercharger. |
07-06-2016, 02:34 PM | #28 | |
John Bednarchik, Corvette Lead Aerodynamics Engineer, as saying the Z51 center section of the front lip was removed for better stability at high speeds. He also. latter in the article, suggests that high speeds are those above 150 mph. Comments is also made about them trying "100" different outside mirror shapes. Further, at the NCM 2015 fest, he was asked if taking them off would hurt. His direct answer was" only at speeds over 150 mph." |
