Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 12-25-2013, 06:51 AM   #1
jgray1978
jgray1978's Avatar
Drives: '12 2SS/RS 45th vert, '14 2SS/RS
Clutch not full height
I've noticed that when I take off in the morning and it's 20ish out, the clutch pedal does not return to normal height at first. I will put my foot under it and pop it back up after which it seems to function normal.
Is this normal?
jgray1978 is offline   Reply With Quote
Old 12-25-2013, 07:37 AM   #2
pocketcthulhu
pocketcthulhu's Avatar
Drives: 2014 2ss/RS 5th gen Camaro #2
lets just say No, I'd take it to the dealer asap.
pocketcthulhu is offline   Reply With Quote
Old 12-25-2013, 08:04 AM   #3
casper sc/1ss/rs
casper sc/1ss/rs's Avatar
Drives: 2011 camaro ss vortech supercharged
casper sc/1ss/rs is offline   Reply With Quote
Old 12-25-2013, 09:06 AM   #4
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Its the crappy stock pressure plate sticking. Do the romote rezzy and keep fresh fluid in it and that will be about it until you can actually put a performance clutch in.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 12-25-2013, 10:00 AM   #5
jgray1978
jgray1978's Avatar
So is it something that the dealer should address or is it something that I should address?
Old 12-25-2013, 10:13 AM   #6
pocketcthulhu
personally if it's under warranty I'd let them get their hands dirty.
Old 12-25-2013, 10:30 AM   #7
Bo White
Bo White's Avatar
If you can talk the dealer into it(if they are going to replace the clutch) get them to put the LS7 clutch in it. Ive heard of a few being done that way.
Totalled:
Old 12-25-2013, 03:39 PM   #8
jgray1978
jgray1978's Avatar
13k on the clock so it should be under warranty.
Old 12-26-2013, 10:00 AM   #9
Steve@SNL/Monster Clutch
Drives: 2014 SS
The factory clutch is an LS7....
Exact same part numbers for the pressure plate, those units are terrible.
Steve@SNL/Monster Clutch is offline   Reply With Quote
Old 12-26-2013, 10:02 AM   #10
Drives: 2014 SS
Is this normal?
Are you driving the car aggressively or are you driving it normally?
If aggressive the clutch is on it's way out and you should take a look at one of our LT1-S street twins, utilizing a GM twin disc from the new C7 it's a fantastic piece that works perfectly in the new Camaros and provides excellent driving characteristics. This is a modified/improved twin disc unit that was used in the ZL1's from the factory.
If normally I'd flush the hydraulics and put a separate reservoir on the setup to keep the fluid separate.
Give us a call for more details.
Old 12-26-2013, 10:38 AM   #11
Bo White
Bo White's Avatar
Maybe that's why some dealerships are bragging on putting those in lol.
Totalled:
Old 12-26-2013, 10:38 AM   #12
Drives: 2014 SS
LOL, I wouldn't doubt it!
Old 12-27-2013, 07:57 AM   #13
jgray1978
jgray1978's Avatar
Well, I have an appointment on Tuesday to drop off the car at the dealer and take a loaner car. This morning the clutch returned to normal height right away. It did grind into 2nd twice within the first couple of miles though.
Old 12-27-2013, 09:14 AM   #14
Drives: 2014 SS
I hope it's as easy as a good bleed, it definitely is clutch related and it sounds like it's not fully releasing.
Keep us updated as things progress!
