10-03-2023, 03:02 AM | #1 |
BOHIC
Drives: 2010 Camaro SS "Enola" Join Date: Jun 2014
Steering wheel horn button
Looking to install a push button on my aftermarket steering wheel for my horn. Anyone tapped into the existing wiring to do something like that? Would be nice to use the existing wiring and just install the switch. I’m thinking it’s just a straightforward install once the wiring is identified.
What else can I do to my Camaro?
10-03-2023, 04:11 AM | #2 |
BOHIC
Looks like grn/wht pin 18 in the wiring diagram I found. Just gotta find what switch or horn to use. Yes I answered my own question
10-03-2023, 12:08 PM | #3 |
That's a cool looking wheel!! Hope you get the horn deal figured out.
11-20-2023, 06:25 AM | #4 |
Drives: Camaro 2017 Join Date: Nov 2023
I did a similar mod on my ride, and it's a game-changer! For the steering wheel horn button, tapping into existing wiring sounds like a solid plan. I went the straightforward route too, identified the wires, and bam—new button in place! Just a heads-up, be sure to check your local regulations to stay on the right side of the law.
As for your Camaro, if you're into DIY upgrades, ever thought about a drill horn? Adds a unique touch and definitely turns heads. Also, consider tweaking the lighting, swapping out decals, or exploring performance mods. Last edited by Alenbaarz; 11-27-2023 at 07:20 AM. |
