dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 07-24-2017, 12:18 PM   #1
climber
Drives: 2012 Camaro LT
Mobil1 LS and Friction Additive
I am seeing a lot of conflicting information so I wanted to get a quick poll on what people think. I was not paying attention and I added 2.5oz of the GM friction modifier AND Mobil 1 LS (with limited slip additive). Closed it up and then realized that the Mobil 1 LS had limited slip. So do I need to redo this? What does too much friction modifier do?
Anyone used the Mobil1 in the manual transmission? Does the friction modifier hurt the 6-speed stock manual? I am having a hard time finding just a 75w90 gear oil without modifiers haha.
For a 2012 Camaro 1LT (V6)
Also for a side of humor... worked on the car for 6 hrs... 3 mistakes later ... potentially further behind then when I started. Beware of the lug nuts with the little metal "casings/covers" they strip REALLY easily. After an hour trying to get it off, I decided that I need to take it to a tire center once I get the trany and differential back to full. This all started because the tire iron from Chevrolet that came with my car doesn't fit my lug nuts! SOOO glad I never got a flat. Doesn't engage at all. stripped two lug nuts and then I stopped. I can't believe the stock tire iron doesn't work haha. So future tire changers beware. Took some pictures if anyone from Chevrolet wants to help me get a replacement!
climber is offline   Reply With Quote
Old 07-24-2017, 03:34 PM   #2
climber
Looks like a good reference. This article seems to recommend a MTF specific fluid that matches the required 75w90 and GL-5. I have Redline MT-90 on order for the Manual Transmission so I will update it if i have any issues.
https://bobistheoilguy.com/forums/ub...pics/1231182/1
Still could use any thoughts on the "doubling up" of the friction modifier
Old 07-25-2017, 08:25 AM   #3
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
FWIW... I used Mobil-1 in my trans and diff, AND also used the GM diff fluid as well. Been on that for a year now and haven't had any issues.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 07-27-2017, 01:11 PM   #4
WoodBoss
"Old School"
Drives: 2010 2SS L99
Amsoil Has that gear Oil. I use in in my differential with their friction modifier.
WoodBoss is offline   Reply With Quote
Old 07-27-2017, 02:11 PM   #5
alrock
alrock's Avatar
Drives: 2015 Camaro Convertible 2SS RS
Same here. No chatter or erratic behavior. I'll probably change it out again when the weather cools off
alrock is offline   Reply With Quote
1 lt v6, differential, friction additive, manual tranmission, mobil1
