07-13-2020, 04:49 AM | #15 |
Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
07-13-2020, 06:21 AM | #16 |
Drives: 1970 chevelle Join Date: Aug 2011
I use a big boi blower that is heated and filtered. They have three a hand held version and 2 roll around sizes I have the more powerful roll around one and it works awesome.I had the metro master blaster their most expensive most powerful blower and the big boi is easier to handle blows more air and hotter air and has a way better hose.
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car 2015 Z06 Z07 Daytona Sunrise Orange Metallic Dads Car 2013 ZL1 vin 963 Crystal Red Tint Coat/Black Wheels Exposed Carbon Fiber Insert 6 Spd Manual |
07-13-2020, 04:34 PM | #17 |
Drives: 2019 Red Hot 1SS "Scarlett" Join Date: Jul 2019
07-13-2020, 05:15 PM | #18 |
If your car is ceramic coated you will almost never need to break out the mitt.
07-13-2020, 06:31 PM | #19 |
07-13-2020, 06:59 PM | #20 | |
If you want to do it yourself, watch some YouTube videos and do immaculate prep work to it. Get the paint looking as good as possible and remove all previous waxes, sealants, contaminants, etc. You’ll also want a dust free environment to let the ceramic cure after you coat it. My friend is a detailer and we did my car over the weekend. But well worth the aggravation.
07-14-2020, 06:57 AM | #21 | |
Drives: 2SS, CT-R, LC500 Join Date: Jan 2018
I did try ceramic coating my Mazda, glad I never tried it on my Camaro. |
07-17-2020, 09:51 AM | #22 | |
Thank you Al Oppenheiser!
https://usa.gtechniq.com/products/au...phobic-coating |
07-17-2020, 10:54 AM | #23 |
Drives: 2018 Camaro 1SS 1LE Join Date: Feb 2020
07-19-2020, 04:15 PM | #24 |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
Here's what I do with my Black SS:
Also in the hinge areas of the car and on my brakes and rims. With the Absorber, the less pressure you use the better. For the roof and windshield, I basically just let the Absorber glide over the surface with the weight of the Absorber only. Also when finished, be sure to keep the Absorber wet in it's container...not dried out. If you are going to seal your paint, be sure to clay your car's surface first. You can test the surface to see if you did a good job with the clay by using a zip loc baggie or plastic grocery bag. Just place your hand in it and run it over the surface, you will feel any areas you missed...it will feel like little bumps. You can also do a before and after test if you like. I hope this helps!
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
07-19-2020, 04:22 PM | #25 | |
07-22-2020, 05:02 PM | #26 |
Drives: 2012 GMC Sierra, 2018 Camaro SS 1LE Join Date: May 2016
I have an old PB603 Echo backpack blower. It's considerably more powerful than whatever you will find at Lowes or Home Depot. I also take an 8 foot ladder so I can blow everything down. As stated previously, the volume is much more important than the speed when drying the car. It seems to work quickly and fairly streak free from what I can tell. Just don't fall off the 8 ft ladder with the huge backpack blower if you can help it.
09-10-2020, 12:11 PM | #27 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
Dewalt blower works well Sent from my iPhone using Tapatalk Pro
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
09-11-2020, 10:05 AM | #28 |
I got one of these and it works very well.
https://www.lowes.com/pd/Kobalt-80-V...ded/1000486243 One charge is enough to blow the driveway clear of leaf-litter before getting The Mistress out for her wash, then blow dry her after. It has good balance and can be easily one-handed without fatigue. The charger has a built-in fan to keep the battery cool when charging. |
