02-22-2023, 09:11 PM | #1 |
Drives: 17 Camaro SS, 14 VMP GT, 14 GT500, Join Date: Dec 2022
17 Camaro SS
Misfires mainly on cold mornings while running E after Texas Speed long tubes, ported LT2 manifold, and flex fuel tune.
It appears to be bank 1 only and cyl 3 and 5 both with over 300 misfires detected. Any ideas? Plugs look fine and were changed 1000 miles ago. I am using AC Delco OEM plugs. See Attached Thanks |
02-23-2023, 08:44 AM | #2 |
Does it misfire on Pump gas? Run some Lucas Ethanol treatment periodically as a preventative measure. E85 likes to gel up on the tips of injectors over time.
2016 NFG 1SS A8
02-23-2023, 10:42 AM | #3 |
Will Techron break different compounds than Lucas?
If not redundant, Techron works well for me
02-23-2023, 11:50 AM | #4 |
Thanks. I’ll try the Lucas.
02-23-2023, 01:08 PM | #5 |
Techron is a good cleaner. I just run the Lucas because it stabilizes all blends of Ethanol and cleans.
2016 NFG 1SS A8
02-23-2023, 02:31 PM | #6 |
2018 SS A8 11.85@117.06
Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
my 18 SS would stumble at start w/ E85 when cold too, I upgraded my coil packs to MSD ones and she purrs like a kitten on start now even in the dead of winter here in Michigan.
DARK KNIGHT
2018 SS A8 11.85 @ 117.07 GPI Tuned E85 stock tires Roto Fab CAI LT 2 intake |
02-23-2023, 07:05 PM | #7 |
I run the Lucas per your recommendation. It’s in my car as it sits in storage.
02-23-2023, 08:15 PM | #8 | |
02-25-2023, 04:15 PM | #9 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
Btw Josh, where do you get your pump E85? or do you use the pure stuff out of the 5 gal containers. Only place I know is the 2 stations right on the Mass Pike right around the interstate Rt 84 area.
02-25-2023, 05:16 PM | #10 |
Yep, my office is in Auburn and the Mass Pike gas station is about 10 minutes away at the Charlton stop…so I load my E85 jugs in the Expedition a few times a year and fill them all up.
02-25-2023, 05:43 PM | #11 | |
I never went to a rental like the one we were at late in October, it was light that day. There was no one in the other lane on my 1 and only pass. BTW, I have stored some E85 in plastic 6 gal gas jugs and it stores just fine inside tightly sealed. |
02-25-2023, 06:06 PM | #12 | |
Yeah I’m hoping to hit that same 4/28 rental but not sure if my new blower will in by then (plus install and tuning time…).
02-25-2023, 06:10 PM | #13 |
02-26-2023, 01:07 PM | #14 | |
What month do you think the summer blend goes into affect? |
