09-16-2020, 11:56 PM | #1 |
Drives: 2017 Red Hot ZL1 M6 Join Date: Jan 2017
Shift Linkage Rattle
I have heard a rattling in my manual gear shift of my 2017 ZL1 for quite a while. Tonight I removed the boot and the rubber lower cover of the gear shift shaft and can hear loud rattling from below the tunnel.
If I press straight down on the gear shift, it stops. Does this sound like a rattle in the linkage? Has anyone else had this problem? |
09-17-2020, 08:58 AM | #2 |
No donald, my 2017 ZL1 shifter doesn’t rattle. Sounds to me like the linkage rods or bushings may be worn or something else going on with the shifter. Now maybe a good time to upgrade to a Hurst shifter!
12-06-2021, 11:21 AM | #3 |
Dangcab
Drives: Camaro 2017 V6 2LT RS - 6 Speed Join Date: Dec 2020
I has the similar issue in my 2017 V6 2LT (Transmission M13), rattle and the free play in the shifters stick, I made a research and decided to upgrade to HURST Short Shifter, so, this last weekend I took the time to make the upgrade and almost at the end of the process I found that the issue has to be the bushings in the Shifter Lever Shaft Joint (Right Picture #3). My problem now is that I can't find that bushings in Internet and I have not the parts numbers and the rattle and the free play in the shifters stick continue.
04-06-2023, 07:04 PM | #4 | |
Drives: '18 RS 2LT, V6 M6, NPP, CAI, Brembo Join Date: Aug 2022
The bushings are now available at www.fullmetalbushing.com for your v6 and i4 model Camaros |
04-06-2023, 07:08 PM | #5 |
Not the rattle, but the play in the shifter is solved with the bushings. The rattle might be a loose shift knob
04-06-2023, 07:50 PM | #6 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Do not rest your hand on the shifter ever. Shift, let go. Only touch when shifting.
but yes need to replace parts on a car that is 5 6 7 years old.
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
04-13-2023, 06:12 AM | #7 | |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
05-02-2023, 10:37 PM | #8 |
There's an overview video on youtube that shows the area to get at it and a screen you can pause with the steps. It's just a pin running through the bushings with a retainer clip on each side. I can assist you with any questions through fullmetalbushing.com contact info. There's good disassembled pics in post #36 here: https://www.camaro6.com/forums/showt...=607655&page=3
If you already did install, how'd it go and how's it feel? Some feedback received for a buyer on ebay made my day. He was so happy to have saved almost $2k and stick it to the local "stealership." |
05-05-2023, 11:14 AM | #9 |
Rawr!
Drives: Giulia Quadrifoglio, C8 Stingray Join Date: Sep 2013
Experienced the exact same thing after receiving my 2018 SS years ago. Brought it back to the dealership and they resolved it under warranty.
This seems like a common issue.
Current:
2023 Red Mist Corvette Stingray 2LT 2021 Trofeo White Alfa Romeo Giulia Quadrifoglio Retired: 2018 Garnet Red Camaro 2SS 2014 Crystal Red Camaro RS |
