09-03-2019, 12:54 PM | #1 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
Tuning on a stock car worth it??
Obviously I know I won't gain much in the HP / TQ department, but I'm talking about more of driveability and having a little less aggressive timing pull tables or rich conditions.
Would it deliver a more crisp throttle response and driving experience overall?
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
09-03-2019, 01:03 PM | #2 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
You will pick up some HP. Drivability? Not significant enough to void your warranty and repay for further tuning if you add mods down the road.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
09-03-2019, 01:37 PM | #3 |
Drives: 2019 GMC Sierra 1500 AT4 Join Date: Nov 2011
No way. Don't tune for less than headers/E85.
Buy a throttle controller or ported throttle body if you want to help throttle response.
Summit White 6" Lift, 37x13.50R24's |
09-09-2019, 06:00 PM | #4 |
Thank you Al Oppenheiser!
09-09-2019, 07:12 PM | #5 |
Drives: 2018 Camaro ss Join Date: Jul 2019
I have to agree. It's best to do all the upgrades and mods that u plan on doing first. Just for $ sake alone. Any mod u add u going to need to retune to get the benefit out of it.anyone that's into adding hp will always look at hp gained vs cost. At very minimum if your considering tune on a dyno. E85.. intake and headers to make dropping 4 to 600 on a tune worth it. I did all my upgrades at once. Cam, headers, e85, rotofab, heads, dod delete, and springs. Still waiting for appointment at Vegence but they did my base tune and it was on point. Cause car very drivable even with just base tune. Highly recommend the one in cumming ga.
09-09-2019, 07:24 PM | #6 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I personally have not been able to improve drive ability at all with a ECM or TCM tuning. That's not to say someone who understands the GM torque based control strategy better than I do or someone with better tools with access to more parameters may be able to though.
I have also not been able to confirm any more power through tuning, I did confirm about 25-29 rwhp peak from E75 and about 5 rwhp peak from NPP in track vs stealth. The biggest drive ability problems being the unnecessarily hard low throttle shifting, overly sensitive and jerky low speed stop and go driving, and the extremely sensitive 50-75% throttle range. I have also tried using the CTS-V parameters, nothing seems to help or even make a difference when changing any of the parameters. Its hard to do unless you have your own personal proving grounds and engine dyno and multi million dollar lab equipment to confirm results, without that its just really good guesses and subjective trial and error. |
09-22-2019, 02:40 PM | #7 |
Drives: '18 5.7 RAM 1500 18' 1SS Join Date: Jun 2009
Power? Not really. After JRE tuned my car it ran better. Just better. I think its worth it. YMMV
JRE Tune
09-22-2019, 04:11 PM | #8 |
Drives: like an old lady Join Date: Jun 2012
tune only, otherwise stock..? i’d leave it be.
e85 and tune on a stock car? certainly.
09-22-2019, 09:12 PM | #9 |
Far as ECM, 93 tune is worth 8-10whp tops. E85 flex fuel tune is worth 25-30whp
Far as TCM, not much to do on a manual. On a A8 3-4 tenths can be gained from a good TCM tune. Driveability can be much improved on over stock as well. Moral of the story. Stock M6 SS on 93 octane...not worth tuning unless you do flex fuel.
2016 NFG 1SS A8
09-24-2019, 09:52 AM | #10 | |
Drives: 2011 Camaro SS/ 2016 Camaro SS Join Date: Jun 2009
Kind Regards, Stephen |
09-25-2019, 12:08 AM | #11 |
E85 is worth the tune. but with a manual there is no other reason to tune until you do headers or E85. both really wake the car up.
09-25-2019, 07:28 AM | #12 | |
Drives: Black Join Date: Jan 2017
The camaro does not suffer from same issues. I barely felt any torque managment, shifts were perfect. It was almost difficult to believe it was the exact same drivetrain. I definitely would not tune a stock car. |
09-25-2019, 08:46 AM | #13 |
My trans tune makes a stock Camaro feel like a turd. Either way OP has a manual so Automatic talk is moot.
2016 NFG 1SS A8
09-25-2019, 10:28 PM | #14 | |
