07-23-2018, 10:06 PM | #1 |
Drives: 2018 1SS 1LE Join Date: Dec 2012
Experiencing slight understeer
Took my usual clover leaf off ramp today and experienced some unusual understeer. I usually have the car in competitive mode when doing this but had all the nannies on this time around. Could the ediff cause the car to understeer ? The tires were plenty hot and was suprised the way the car acted mid turn.
07-23-2018, 10:48 PM | #2 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
What state are the tread depth of your tires in?
In general as your tires wear down , the car will feel more stable (less tread squirm), but will lose a little grip.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
07-23-2018, 10:50 PM | #3 |
Could also be just the e-diff and systems working as well. Comp. mode leaves you with full traction at your control and just uses Stabilitrac.
What mode were you in?
Current:
07-24-2018, 06:16 AM | #4 |
Drives: 2017 1le current /2015 2ss 1le sold Join Date: Jan 2016
Understeer is typically caused by the pilot..
2017 1LE Hyper Blue
07-24-2018, 06:44 AM | #5 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
07-24-2018, 08:08 AM | #6 |
Drives: 2017 Camaro 1LE SS Join Date: Oct 2016
If you haven't gotten an alignment you need to. Factory alignments are off 95% of the time. That can definitely cause understeer. And no the ediff will not cause understeer.
07-24-2018, 08:18 AM | #7 | |
Our elsd has 4 different settings in a stock car depending on what mode one selects. If you dont select any elsd will be in its least aggressive mode dialed for safety and stability as priority. Hence one may absolutely feel more understeer. |
07-24-2018, 08:34 AM | #8 | |
Drives: A few Join Date: Oct 2017
From the OP, we don't know what he was doing with the pedals and wheel, so I won't say that the eLSD didn't help cause what he experienced, but I wouldn't say it did either without more info (ie, throttle position, steering angle, etc). The OP is used to that corner in comp mode, which is far more aggressive on torque delivery. I forgot which eLSD mode it uses but it's not the least aggressive.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback Too many cars.. never. |
07-24-2018, 08:44 AM | #9 | |
08-09-2018, 12:51 PM | #10 |
But that is exactly what I am saying. The elsd didn’t cause it the mode and ecu did. Dave is correct in needing way more info for this to be helpful. Lol
