04-13-2018, 09:29 AM | #1 |
Drives: 2ss Join Date: Jan 2018
ET difference with skinnies
Curious on the gains by running a 17x4.5 skinny vs stock front
I am set up with a bias ply slick for the rear and have read and heard horror stories on mixing bias ply and radials on a car. |
04-13-2018, 09:54 AM | #2 |
SNSTRSS
I'm curious too about running skinnies. I have a 305/40/18 MT DR in the back and plan on adding a 28x4.5x17 MH radial upfront. Will this help et and how does it feel on the street?
2016 Black Camaro 2SS A8 NP
04-13-2018, 09:55 AM | #3 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
You’ll pick up around a tenth
They drive fine. Just corners like crap. Have to go around them much slower |
04-13-2018, 10:03 AM | #4 |
So would you say the price to gain ratio is worth it or better spent on other bolt on mods?
Anyone run a bias ply slick on the rear with a radial street tire on front with no issues? |
04-13-2018, 10:06 AM | #5 |
SNSTRSS
04-13-2018, 10:10 AM | #6 |
Drives: 2017 Camaro Join Date: Mar 2018
04-13-2018, 10:21 AM | #7 |
04-13-2018, 10:33 AM | #8 |
If you drive the car on the street a lot then don't put skinnies on it. I had 17x4.5's on my 4th gen for a year and went back to 17x7 because braking is compromised along with handling. If you have to make a quick maneuver due to some idiot on the road its not going to end well. And before I get a response that I am comparing a 4th gen...mine is not stock suspension or brakes. It still not quite as good as a 6th gen stock but it's close so I feel its a comparable situation.
2016 NFG 1SS A8
04-13-2018, 10:37 AM | #9 |
I am just planning to run them for local list racing at the drag strip. I live 4 miles down the road from the track and plan to throw them on and cruise down the back streets to get there and race, then throw my street tires back on to drive on street.
04-13-2018, 10:37 AM | #10 | |
If you drive them on the street and go with 17x4.5 you need to be cautious. Like I said they handle like crap. You are only driving 4 miles that’s nothing. I have to drive 80 miles to the track on them. |
04-13-2018, 10:48 AM | #11 |
Whoa, I bet that makes for an alert trip.
04-13-2018, 11:07 AM | #12 |
Yep. As was said everything is worse not just turning. Braking won’t be as good either
04-13-2018, 12:33 PM | #13 | ||
Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
I would strongly suggest to anyone looking to go skinnies to go bias ply up front regardless of rear tire, you will thank me later. To my surprise, they both weigh the same at 17lbs too.
04-13-2018, 01:05 PM | #14 |
Well I am cutting myself off on ordering parts for a few minutes. I broke down and ordered the 17x4.5 front wheels and made Summit beat the Jegs price on the Hoosier 27.5/4.5-17 bias ply front runners.
I think my next venture will involve gathering parts until I am ready to bolt it all on and get a tune. Thanks everyone for the helpful input on this stuff, its greatly appreciated. On that note, what tire pressure you run on the fronts? |
