Old 12-06-2019, 07:43 PM   #1
OVRKLL
Drives: 2017 1SS 1LE...makes me go YeeeHaw!
Header Heat?
Does anyone know how hot headers get after:
  • Track day runs
  • Driving around town stop/go
  • Freeway driving, interstate cruise
I want to purchase some heat resistance tape to use in different areas under the hood and starter solenoid, it resists direct heat 400f and radiant heat to 2000f.
Not sure if this is good enough especially for the starter solenoid, and I don't want to use a blanket, seems like I'd have to remove the starter...no, no.
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late!
OVRKLL is offline   Reply With Quote
Old 12-07-2019, 09:24 AM   #2
enzia35
Drives: '16 Garnet Red 1SS
You didn't get ceramic coated headers?
'16 Camaro 1SS
'18 Miata GT
Old 12-07-2019, 05:12 PM   #3
OVRKLL
Yes I did, but just wondering if the OEM starter heat plate will be enough to protect it from the headers, since it is kind of close.
Old 12-07-2019, 06:42 PM   #4
SanDMaN2091
SanDMaN2091's Avatar
Drives: 2016 Camaro SS A8 NPP
Crusing..mine are around 900ish. WOT I've seen high 17s low 18s. But the ceracoat helps alot with dissipation
DMS Flex Fuel-E85
HPTuners Ngauge
Roto Fab CAI,
LPE Ported/Polished 95mm LT5Throttle Body,
PRAY Ported MSD Intake Manifold,
SP Coated TSP 1 7/8" Catlless Longtubes
Hooker BlackHeart Cat-Back,
Mishimoto Catch Can (Which always has some nasty in it)
Instagram@Weapon_6
SanDMaN2091 is offline   Reply With Quote
Old 12-08-2019, 07:37 PM   #5
OVRKLL
Dayum!
That's hot!
That starter heat shield may need a little help after all.
Thanks!
Old 12-09-2019, 11:48 PM   #6
JGiovando
Drives: 2018 1SS 1LE HBM
OP....my headers are ceramic coated but I went for a lava starter shield from heat shield products. Put it on same time I installed headers. No issues with heat tracking the beast in south Florida mid-summer. At least none so far
JGiovando is offline   Reply With Quote
