Old 11-10-2019, 12:02 AM   #1
Pupilbone
Pupilbone's Avatar
Drives: 2019 Crush ZL1 M6
IROC Motorsports - IROC z rims?
Has anyone gone with these? Love the look, but would like to see some pics on Someone’s 6th Gen...
Availability: In Stock.
Sizes: Front 20×10 20mm offset / Rear 20×11 43mm offset
Includes: Set of 4 (2 front/2 back)
Fits: 2010-2021 Camaro
Shipping Cost: FREE Shipping
Thanks,
#SaveTheManuals
Pupilbone is offline   Reply With Quote
Old 11-11-2019, 11:35 PM   #2
Metal2SS
Drives: Silver Ice 2017 Camaro SS
My Sizes : 275/40/20 315/35/20
bought mine with the tires as like a combo deal so not my preferred sizes.
https://i.imgur.com/NHgFNUw.jpg
https://i.imgur.com/HPEpqVH.jpg
https://i.imgur.com/YlyqCIX.jpg
Metal2SS is offline   Reply With Quote
Old 11-12-2019, 12:07 PM   #3
Carlos_MRRWheelsInc
Carlos_MRRWheelsInc's Avatar
Drives: camaro
Just a little advice as a friend. the tire set up you currently have is for the 5th gen Camaro. this set up is to big for the 6th gen, I would recommend looking into the inside rear quarter panel liner as Im sure you are currently experiencing some minor rubbing, the reason I recommend you looking into it is because the rubbing is exactly at the wire harness point area which if you let it continue you will completely rub off some wires and cause some major issues, the easy fix is to simply place the harness over to the back with some zip ties or simply change the tire set up.
you should be running 285-30-20 fronts and 305/30-20 rears but we know these tire sizes are limited and pricey compared to the size you currently have. Any way just letting you know and hopefully save you from some headaches later down the road.
( Sorry for some reason I thought you had a 6th Gen ) your good on the tire size !!
Carlos_MRRWheelsInc is offline   Reply With Quote
Old 11-12-2019, 02:16 PM   #4
Metal2SS
I moved the harness already so im good on that front the liner has been rubbed through already though lol . the tires where brand new so like might aswell run em' right? ... right? anyway looking at ps4's as the next tire.
Old 11-17-2019, 05:30 PM   #5
Pupilbone
Pupilbone's Avatar
Thanks Metal, they look great!
#SaveTheManuals
