Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 12-12-2017, 02:35 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Gears
What is a decent gear set that can handle a launch or two?
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 12-12-2017, 06:34 PM   #2
jrhagen
Drives: Camaro
I have a ZL1 diff with 3.73 gears. Hundreds of launches so far with 700+ whp.
jrhagen is offline   Reply With Quote
Old 12-12-2017, 08:32 PM   #3
QUICRNU
Drives: Z06 wannabe
What he said, except I have the 3.23 and we both 60ft low 1.40s
I think alot of guys go with a TruTrac + Lpw cover etc etc if sticking with the stock rear. I think 3:73 or 3.91 would be good with those turbos?
I found the ZL1 rear most economical by a long shot.
Apex Focused
QUICRNU is offline   Reply With Quote
Old 12-13-2017, 08:11 AM   #4
2010_camaro
Wasn't sure if the OE gears was a weak link or not
Old 12-15-2017, 11:00 PM   #5
2010_camaro
Is motive gear a bad company? I've heard several people saying to not go with Richmond gears so I don't know who to go with.
Old 12-18-2017, 04:40 AM   #6
Slickcas
Drives: 12' 2SS/RS LS3 IBM
The stock gears are very tuff. Made by AAM American Axle &Manufacturing. They generally do not break. The stock SS housing is aluminum and it will flex. Causing the gears to go out of alignment. I have been using 3.91 gears with JRE caps and LPW cover. That combo seems to last.
But I am doing a Turbo400 swap with transbreak this winter so I am swapping out to a ZL1 3.73 diff. Just to be on the safe side.
Slickcas is offline   Reply With Quote
Old 12-18-2017, 12:44 PM   #7
Redgt03
Redgt03's Avatar
Drives: 2011 Camaro SS
Are you going to sell your diff. With the 3.91? I am in Peoria and I am planning that swap next year.
Redgt03 is offline   Reply With Quote
Old 12-19-2017, 03:57 AM   #8
Slickcas
Yes I will have my SS diff with the JRE upgrade with 3.91 gears and LPW cover. Also DSS driveshaft and 1000hp Axles.
Old 12-19-2017, 08:51 AM   #9
Redgt03
Redgt03's Avatar
Let me know what you want for the diff when the time comes. How many miles on it?
Old 12-19-2017, 09:41 AM   #10
Hixson
Hixson's Avatar
Drives: 2015 Camaro 1SS L99
^^also interested in 3.91 diff if it falls through with Red. Doing tons of winter projects to the car, would love to cap it off with gears if I could make it happen
Hixson is offline   Reply With Quote
