dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 11-29-2017, 02:01 AM   #1
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
3200 or 3600 stall for L99?
Hey guys,
The stall is next on my list for performance, but I can't decide between a 3200 or 3600 stall. I *may* get 3.91s at some point in the future, but not anytime soon. I would LOVE to get a cam, but I can't realistically see that happening for AWHILE.
Car is a daily driver with bolt-ons, and I have a tranny cooler already.
I'm leaning towards Circle D right now.
Thanks!
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 11-29-2017, 06:48 AM   #2
IMPERIALBLUE2SS
Drives: 2010 imperial blue LS3 M6 2SSRS
I would wait until you decide which cam you want. Cam and converter go hand in hand.
IMPERIALBLUE2SS is offline   Reply With Quote
Old 11-29-2017, 07:48 AM   #3
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Go ahead with the 3600 if theres a possibility of cam swap in the future.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 11-29-2017, 08:24 AM   #4
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
converters can be refreshed/re-stalled...since you too have a dynoSteve tune, have you asked him? just sayin since the tune would change too...right?
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 11-29-2017, 11:09 AM   #5
LCPLPunk
USA-1
LCPLPunk's Avatar
I think the stall has to be pulled out to change the stall speed though. :P I don't see myself doing the labor to do that.
Old 12-04-2017, 07:49 PM   #6
LCPLPunk
USA-1
LCPLPunk's Avatar
So, Chris at Circle D said 3600...
BUT, I got an email back from DynoSteve and he's asking why such a high stall (3600)...LOL
Old 12-04-2017, 08:57 PM   #7
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
I emailed Circle D and with my set up 3200 is what they suggested. 3200 drives like stock until you hammer it....3200 stall with 391s makes a good cruiser.
rontammy0 is offline   Reply With Quote
Old 12-04-2017, 09:13 PM   #8
briancamaross
briancamaross's Avatar
Drives: 2011 ss 2ss auto camaro
Stay with 3600 it should work with most cams that you could pick.
2011 2ss white Camaro mods are texas speed stage 4 cam 235/239 Texas speed 2inch headers no cats magna flow bullet mufflers gpi rod mod ,circle d 4000-4200 5c stall. 3.91 gears vararm cai power wedge.
briancamaross is offline   Reply With Quote
Old 12-04-2017, 10:22 PM   #9
jrhagen
Drives: Camaro
It's called a convertor, not a stall.
jrhagen is offline   Reply With Quote
Old 12-05-2017, 06:13 AM   #10
Rob10CamaroSS
Drives: 2012 ZL1 Redline Phase 4
If your not use to driving higher RPM convertors 3600 may be a bit much for you. Dont get me wrong I've had a lot higher in some of my cars but we're talking 600 to 800 HP with cams that were so extreme you needed it.
With a stock motor & cam 3200 is a great choice, if you plan on really camming it up then maybe I'd consider the 3600.
2012 ZL1 w/Redline PHASE 4-ZL Performance Package
Rob10CamaroSS is offline   Reply With Quote
Old 12-05-2017, 06:42 AM   #11
Bo White
Bo White's Avatar
I daily with a 5000 stall so just keep that in mind....
Totalled:
Old 12-05-2017, 08:28 AM   #12
Hixson
Hixson's Avatar
Drives: 2015 Camaro 1SS L99
Go with 3200. You only need the 3600 and higher if you are planning on running someones stage 4 cam kit (for the most part). Most of those kits require some flywheel cutting etc if I'm not mistaken, and that doesn't sound like something you would be interested in doing from reading your other posts.
My 2 cents - go with a 3200 stall and enjoy. Add the 3.91 gears down the road, and eventually add a stage 1-3 cam from an awesome forum sponsor like Gwatney Performance, Texas Speed, etc. All of those pieces pair together nicely so it would be a nice buy that meshes well with your future plans
Hixson is offline   Reply With Quote
Old 12-05-2017, 08:39 AM   #13
frankwjr
frankwjr's Avatar
another thing...a converter will flash higher at launch depending on how much TQ is hitting it..I hear any where from 300 to 500 RPM HIGHER than listed...so your 3200 will behave for DD but if you hit it off the line the higher flash will get you into the r's faster..
when does your xfer come thru? already made plans for shippin the car?
Old 12-05-2017, 09:04 AM   #14
LCPLPunk
USA-1
LCPLPunk's Avatar
Thanks all for the suggestions! I really think the 3200 sounds like the better choice for me right now. I'm not wanting the fastest car out there and am more interested in a quick daily driver. My car ships on Friday actually!
