06-06-2017, 04:09 PM | #1 | |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
Guide: Touch-less Car Wash with Clarity1 Sano Suds
Now this guide outlines how to watch the car using a touch-less method, but yes I do follow up with product to add additional shine. No ceramic or simple soap wash has proven to provide a shine that that is deep. Ceramics always look good at first, but overtime the pure shine needs a boost.
06-06-2017, 08:40 PM | #2 |
This will work for a car that had nothing bonded to the paint as stated.
If the car has been driven in the rain, I realize it doesn't rain much where you live, but if someone is in an area that does get rain, this method will not remove all the film. The reason your glass isn't clean is because it hasn't removed everything off the car. You cant look through the clear coat like you can the glass. So if your glass isn't clean, your paint isn't either. Using APC to remove bird bombs or bug splatter will work, but it will also remove most waxes and sealants that are on the paint as well. You'll want to apply protection to these areas when your done. This soap also contains carnauba wax in it. It's been my experience using SI02 products like the Hydro 02 you use, that when covered with wax or glaze, it diminishes the hydrophobic effect. Since your car is garaged and doesn't get very dirty, I'd recommend you look into rinseless washing. Glen on this forum has a good procedure for it.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. |
06-06-2017, 10:01 PM | #3 |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
I agree with Joe...Rinseless washes with a good Sio2 product works awesome, before polishing and sealing with a good Sio2 product. Carpro makes some awesome products. No need for a pressure washer, too much work and will never get as clean and glossy as a good rinseless wash using a really good Sio2 product.
06-07-2017, 09:09 AM | #4 |
Pat
Drives: 2017 Camaro 1LT I4 Turbo A8 Join Date: Nov 2016
Great video! Probably going to get CQuartz this month and the touchless will come in handy.
Follow me on Instagram @whiskeyfed
Subscribe on YouTube Whiskeyfed Camaro Follow my Build Thread The WhiskeyFed Camaro Current Modifications: JacFab Boost-O-Lator, Injen Evolution CAI, ZZP Catless Downpipe, RPM 3" Charge Pipe, Mishimoto Oil Filtration/Coolant Systems, R1 Concepts Brakes Package, Eibach Pro-Kit Lowering Springs, PTP Lava Exhaust Wrap & Turbo Blanket DYNO SHEET: 297whp / 374wtq Tuned by #danytechtuning |
06-07-2017, 10:22 AM | #5 |
If your getting CQuartz the shampoo you want is the Carpro Reset.
06-07-2017, 10:33 AM | #6 |
Pat
Roger, Rodger (ahem, I mean Joe). Thanks!
06-07-2017, 12:01 PM | #7 | ||
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ! Join Date: Sep 2015
06-07-2017, 09:12 PM | #8 |
Drives: 2016 Blue 2SS Join Date: Mar 2016
touch less just doesn't work. I've tried tons of different soaps in my foam cannon now, probably around 25 different soaps and none actually work at cleaning a dirty car. If it rains and I have the dirty rain spots all over the car, touch less will do nothing. The only thing I can see touch less working for is if all i have is dust particles. Unfortunately this method won't work for you if you get the car dirty, the only reason it will appear to potentially be clean is because it's a white car.
06-13-2017, 11:52 AM | #9 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
My car does not have to be spotless 24/7. I do touchless washes and then spot wipe the really bad spots gently. Anytime you wipe or scrub, you risk marring the paint.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
06-13-2017, 06:54 PM | #10 |
touchless just doesn't work, i'll take a video tomorrow of my very dirty car from the ran, not pretty much clean like you see on youtube, and i'll post the results. I'll be using the honeydew wash from chemical guys, you'll see how it basically does nothing to the film.
06-13-2017, 08:45 PM | #11 |
I rinse with a pressure washer. I put 1 oz of rinseless wash concentrate in my foam cannon with the soap. I have Honeydew Snow Foam as well as 30 others. Some are better than others. I foam the car , let it dwell for 5 minutes, then pressure wash rinse. I blow it dry after that it spot dry using McKee's Fast Wax as a drying aid.
I use Tame Tiger touchless brake dust remover. It absolutely is touchless and will get moderately dirty rims clean with just a spray and pressure washer rinse. It's not for after driving in the salt and snow, but when you just want a pretty clean car to go out in, not go to the car show, touchless is a great way to not swirl up your paint. And it only rains about 4 times a year where Matt lives anyway.
06-13-2017, 09:28 PM | #12 | |
06-13-2017, 10:23 PM | #13 | |
I'm not saying it gets totally clean with this method. I still wash with mitts to get the road film and salt, etc. Just not 3x a week like I used to hahaha! After spending 5 days polishing this car back to 100% paint correction, I am doing whatever I can do avoid swirling it up again!
06-14-2017, 06:03 AM | #14 |
I've tried a touch less wash a couple times using only CG Honeydew soap, foam canon, pressure washer and dried with blower. It does knock some dirt off off but not enough for me. Last time I tried I followed up with a rinseless wash and saw the dirt on my towels. I concluded that touchless really doesn't work well at all.
