01-12-2021, 09:40 AM | #1 |
Drives: '18 Camaro ZL1 1LE Join Date: Nov 2020
Bored of the power already.. time to make some jam
Two months ago I added a Rotofab intake, DSX flex fuel sensor & dyno tune from MSorian, my 1LE made 580whp/541wtq on 93 & 598whp/554wtq on E60 blend. Sorian said he couldn't really push the timing too much because the stock cats would blow out, I was completely fine with that and the car has been great.. but I'm a bit used to the power now.
Fast forward 2 months.. my new bolt ons just arrived! CSP headers, ATI damper & 9.17 lower pulley, Weapon-X heat exchangers and one step colder NGK plugs. It'll all go on this weekend and back to Sorian she goes next week! Any guesses on how much whp/wtq she'll make now? |
01-12-2021, 09:51 AM | #2 |
Drives: women crazy Join Date: Aug 2020
581hp
‘19 1SS A10, Borla S-type Non-NPP-SOLD
01-12-2021, 10:13 AM | #3 |
Drives: 2019 ZL1 Crush Join Date: Jan 2019
more than you make now?
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
01-12-2021, 10:15 AM | #4 |
652/665
01-12-2021, 10:58 AM | #5 |
Drives: '18 ZL1 1LE Join Date: May 2020
I'd be careful running E60 with all the mods you're putting on if you don't have an aux. pump or JMS voltage booster. You'll likely run outta fuel. Probably still put down 640-650whp though!
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
01-12-2021, 10:58 AM | #6 |
The old adage is to decide at the outset what you want your car to be and do it the first time. However, I prefer a car that allows for future mods. Of course our LT4 short block is a major limiter but it's hard to step into a billet short block at the outset.
'20 ZL1 1LE A10,
01-12-2021, 11:02 AM | #7 |
Agreed. Low side is the first to go and will screw up the rest when it does. JMS is a good way to go unless you're planning for over 800 WHP down the road...in which case go with triple in tank pumps and get it over with.
01-12-2021, 12:42 PM | #8 |
How is an LT4 short block a limitation? What is the power level that you should consider a forged bottom end?
2019 Crush A10
01-12-2021, 01:10 PM | #9 |
Drives: 17 SS a8 Join Date: Feb 2010
Lol, lt4 short block a major limiter? And then the logical step up is a billet block?
Anyways, watch those fuel pressures.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
01-12-2021, 01:21 PM | #10 |
I have no personal experience with the limits of this particular short-block and can only say that Hennessey believes that it must be rebuilt for 1000hp and up. My experience with the LS1 short block was that it had comparable limits.
'20 ZL1 1LE A10,
01-12-2021, 02:41 PM | #11 |
Drives: 2018 ZL1 Join Date: Oct 2019
I have similar mods and you can maybe run e40 max. Guessing 655 RWHP
2018 ZL1 A10 - Rotofab Intake, LT5 TB, TSP Headers, ATI Balancer, 9.1 Lower Pulley, JMS BAP, Flex Fuel.
01-12-2021, 02:45 PM | #12 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
Matt used a pretty stingy dyno. I say 620/640 on 93 and 650/670 on e40 without low side booster. Hope you are going catless tho?
01-12-2021, 08:05 PM | #13 |
Drives: 18 ZL1 Convertible Join Date: Jun 2019
01-12-2021, 08:51 PM | #14 | ||
