12-30-2020, 05:10 PM | #1 |
Drives: 2020 Camaro SS 1LE Join Date: Nov 2020
Headers
So to my understanding i have an x pipe by borla ( https://www.lmperformance.com/828520...-ss-v8-62.html )
and i was looking at the the size of the pipe and its 2.75 inches and i was wondering if these headers will fit with a 3" https://www.texas-speed.com/p-6846-t...ess-steel.aspx Also i heard the 2" headers are a tight squeeze so if any one knows the differences between the 1 7/8" please say. Last question and when they say catted connection is that high flow cats they give you or just regular cats. |
12-30-2020, 05:55 PM | #2 |
Drives: 2020 SS 1LE Join Date: Aug 2020
Im not sure on the TSP headers but, my ARH 2" I installed two days ago had plenty of clearance all around. As for the catted connection, typically that means hi flow cats, in regards to connecting to your existing Mid-Pipes, it will require some modification of some sort. The ones I have seen have needed a small piece of pipe to merge the two. Unless its a matching set like ARH or Kooks, or Corsa.
01-01-2021, 05:57 PM | #3 | |
01-01-2021, 10:08 PM | #4 |
Drives: 2018 Camaro SS Join Date: Aug 2020
kooks makes headers with high flow cats on them. im looking to get them with my borla x-pipe and atk.
https://www.phastekperformance.com/K...headers-02.htm
2018 Camaro SS - Hyper Metallic Blue |
01-02-2021, 07:50 AM | #5 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
I'm pretty sure that the cats supplied with all aftermarket headers are referred to as "high flow" cats. You can upgrade to green or GESI converters for a couple hundred bucks. The GESIs don't flow any better, but they can withstand more heat.
Baby Blue
01-02-2021, 11:29 PM | #6 | |
I went with ARH because of their long system and because I’ve use them on my past 4 vehicles and not once did I have any issues with them. |
