Old 07-03-2018, 07:49 AM   #29
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
Some might say that the ZL1 1LE is possessed. Maybe it is...
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 07-03-2018, 08:25 PM   #30
Firehead640
DEVLMAN
Drives: White 2018 ZL1
It was a hot day in Arizona when I noticed this:
Seems to be the same exact issue. I'll wait until everything cools down significantly to go have a look. I don't mind if it is only when it gets hot does it do that, but it might be worth a fix.
Firehead640 is offline   Reply With Quote
Old 07-03-2018, 09:21 PM   #31
devnull
Scientific negotiator
devnull's Avatar
Drives: 2019 Grand Sport
That's not too bad at all.
2019 Grand Sport M7
2018 ZL1 1LE 6MT
2017 SS 1LE 6MT
Matthew 25:40
ΜΟΛΩΝ ΛΑβΕ
devnull is offline   Reply With Quote
Old 07-03-2018, 09:22 PM   #32
devnull
devnull's Avatar
Originally Posted by Thesilent1 View Post
What youtube channel because i cant find it on youtube
Try this one bud. Not bad at all to do.
2019 Grand Sport M7
2018 ZL1 1LE 6MT
2017 SS 1LE 6MT
Matthew 25:40
ΜΟΛΩΝ ΛΑβΕ
Old 07-06-2018, 12:07 AM   #33
Firehead640
DEVLMAN
Had a look when it "cooled down" here in Phoenix, and it still really bad. I'm hoping that it won't remain that way, going to see if Chevy will cover it on their time to correct it, along with the horrid alignment.
Old 07-09-2018, 07:58 PM   #34
Travis959
Drives: 2019 Camaro 1LE
Thanks for the tip. Mine was doing this as soon as it started getting warm, so about a month or two after buying it. Mine started doing it on the driver's side but then moved to the passenger side as well. Zip-tied it right up, saves me a trip and hassle of going to the dealer.
Travis959 is offline   Reply With Quote
Old 07-22-2018, 02:40 PM   #35
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
+1
Going to the dealer sucks...
2018 MBM ZL1 1LE - Stock
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 07-22-2018, 07:51 PM   #36
Grumpy1
Grumpy1's Avatar
Glad I found this thread, noticed mine is doing the same thing on both sides of the car. The lines were perfect when I bought it in Jan. till today.
I was thinking (hoping) it maybe a heat issue as this has been the hottest so far this year. Also due to the fact I remember reading about the front bumper on the corvette having similar issues.
At lest there seems to be a simple fix if it doesn't pop back into place.
Grumpy1 is offline   Reply With Quote
Old 08-10-2018, 10:26 PM   #37
Bred03
Drives: 2017 Camaro 2SS Redline Edition
Thanks for posting this solution
I bought the GM body kit for my SS and installed it myself. The rear diffuser that came with it required me to remove the rear bumper. When I put the bumper back on both sides of the car had the same gap you had. I used your zip tie solution and it solved the issue.
Bred03 is offline   Reply With Quote
Old 08-30-2018, 03:45 PM   #38
TMS
TMS's Avatar
Drives: 2018 ZL1 1LE - HBM, PDR
Great thread. Thank you.
Before
After
JRE Tuned (HPTuners) | 15% OD (9.17" crank pulley) | TVS2300 Maggie Heartbeat Supercharger - 14 psi | E-50 (DSX Flex Fuel kit) | JMS FuelMax Fuel Pump Booster | LPE Big Bore High Volume DI fuel pump | LPE High Flow DI fuel injectors | LT5 95mm TB | RotoFab CAI | AEM X-Series OBD2 wide band gauge | Elite Engineering E2-X catch can | Borla S-type NPP Cat-Back 3" exhaust | Forgeline GTD1 5-lug Satin Graphite | SunTek wrap | C-Quartz Finest Reserve ceramic coated
TMS is offline   Reply With Quote
Old 08-30-2018, 05:05 PM   #39
g26er
Drives: 2018 Camaro SS
I know this is a ZL1 discussion but, my SS does it too... equally on both sides. I haven't really had a chance to check it in cooler weather since I've had it 6 months and live in the Florida heat.
I wish I could have seen this thread and did the zip tie trick while swapping to GM dark tails two months ago. It's not too bad and doesn't really bother me anymore so, not going to worry about it.
My father has worked as a body man his whole life and has owned his own shop for a majority of that time so, it's habit for him to look at gaps and lines and he's actually the one who pointed it out to me. He also kindly pointed out that the gap between the edge of the passenger door and rear quarter was larger than on the drivers side. I told him I'd take him for a ride if he stopped inspecting everything
g26er is offline   Reply With Quote
Old 08-30-2018, 05:14 PM   #40
Grumpy1
Grumpy1's Avatar
Mine returned close to normal about a week after it kind of cooled down some. In fact it's really not worth pulling the taillights out to zip tie as it's not that noticeable right now.
Old 08-30-2018, 05:20 PM   #41
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
Mine is dong it as well, just noticed it today. Most likely heat related as others have said.
Thanks for the tip, I'll be doing mine tomorrow
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp
VAZL1 is offline   Reply With Quote
Old 08-31-2018, 05:43 AM   #42
Raven87
C'mon- really?
Raven87's Avatar
Drives: Looking for a ZL1
Good thread and the pics are excellent. I have a black 2SS 1LE and have not noticed it yet but now will be looking for it closely.
But I'm just curious where the expansion/movement of the plastic bumper is moving to once the zip ties are in place? Given that the material obviously expands due to the heat, if the movement is restricted by the zip ties but the material is still heating up, doesn't that expansion have to go somewhere by the laws of physics?
Just curious if you have noticed a change elsewhere once you zip tied the bumper from moving outward?
Steve
2018 Camaro 2SS 1LE Black #3805 - SOLD
Raven87 is offline   Reply With Quote
