Old 04-11-2016, 09:03 AM   #1
HumanWiki
Drives: Car
Key Fob doesn't work in a certain parking lot
Whelp, finally found a place where my car will fully refuse to answer the keyfob. I had to "break in" to my own car yesterday by pulling the vanity cap on the door handle and using the mechanical lock to get it and then place my fob in the rear cup holder.
It's only my apartment parking lot that does it and it doesn't matter where in the lot I park. I can be even on top of my car, from the front, sides, rear, holding against glass, under the fender (trying to block external radios), near the rear lights, etc. Nothing... It'll kinda flicker from time to time, but not consistently.
It only does it in this parking lot and nowhere else. In fact, the 1st time it happened, I just thought my fob battery was dead, dying or the remote got wet because it was raining. But, having tested it out, it is specifically this parking lot for my apartment.
How have other people gone around this issue when they're getting external RF interference from the local environment? This is my apartment complex I'm just now moving in to, so it's not somewhere I can really avoid.
HumanWiki is offline   Reply With Quote
Old 04-11-2016, 09:10 AM   #2
SPARTAN sui
PC Technician
SPARTAN sui's Avatar
Drives: 2016 Hyper Blue 2SS
Hmm, have you tried the onstar app? You get to use the remote app for 5 years. That might be a suitable workaround.
SPARTAN sui is offline   Reply With Quote
Old 04-11-2016, 09:14 AM   #3
HumanWiki
Drives: Car
No, I won't use the OnStar App. I read through their TOS and EULA and found their terms to be questionable. Specifically the parts referring to me giving them the right to have my app transmit phone telemetry even if the application isn't running in the foreground. That's a huge no-no in my book.
Old 04-11-2016, 09:30 AM   #4
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
yes, see it before...saw it in person last year at a BMW dealership, the used car lot would not get fobs due to towers close to lot...
Old 04-11-2016, 10:07 AM   #5
Dustya
Drives: Overkill Supercharged 2016 CamaroV6
Talk to dealer maybe they can reprogram the frequency to another band kind of like you would have to do with a router if you were getting interference. Then they will have to reprogram you key fobs.. Not even sure if it's doable
Dustya is offline   Reply With Quote
Old 04-11-2016, 01:42 PM   #6
c5Legend
Camaro5
c5Legend's Avatar
Drives: 2010 Camaro 2LT
Have you asked your neighbors if they have the same issue?? that would suck lol
My Build
'11 Chrysler 300 Limited / '10 Camaro 2LT
c5Legend is offline   Reply With Quote
Old 04-11-2016, 02:34 PM   #7
ussj4brolli
Drives: 2x 94:Z28s - 2x95:Z28s - 1x16:1LT
+1 for on-star application.
ussj4brolli is offline   Reply With Quote
Old 05-24-2016, 09:40 PM   #8
iceniu2003
iceniu2003's Avatar
Drives: 2016 2SS Summit White A8
That's really odd, never heard of anything like that before. It kinda makes me want to go to your lot parking lot and see if I have the same problem.
iceniu2003 is offline   Reply With Quote
Old 05-24-2016, 10:29 PM   #9
andrec10
Drives: 2016 Camaro 2SS 6SP/Suby Legacy 6
Aliens? NSA?
TFPK40
Its Here! Finally came home on 3-31-16! Red Hot 2SS,6 Speed, NPP, MRC, Adrenaline Red interior, Silver Rally Stripes, NAV, Sunroof, 56W Split Spoke Wheels, Body color Hood vents, Body color Splash Guards and winter protection package.
Ordered 1-28-16: 1100
2-11-2016 :2000
2-15-2016: 3000 TPW of 3/7...That went quick!
2-26-2016: 3400 Status TPW 3/7
3-5-2016 : 3800
3-8-2016 : 4300
3-11-2016 : 4B00
3-15-2016 : 4200
3-22-2016 : 4800
3-29-2016 : 6000!
andrec10 is offline   Reply With Quote
Old 05-25-2016, 03:50 PM   #10
L&M CAMARO 6
L&M CAMARO 6's Avatar
Drives: Just a fan for now
First world problems my my why do we even need this remote *&^%)(?
Also why make cars that can be hacked by some teenager?
ENJOY!!
L&M CAMARO 6 is offline   Reply With Quote
Old 05-25-2016, 03:58 PM   #11
HumanWiki
Drives: Car
As an update. A friend of mine had a loaner. A 2016 Nissan Altima. His remote failed exactly the same way mine did. He had to use a manual key to enter the car and then pocket the fob to start the car. His other cars, both older, don't have this problem with their fobs. Nor does his fiancee's 5th gen nor did my 2012 Grand Sport. So there's something with newer cars that's causing them to be susceptible to this issue.
There is something in the vicinity, a cell tower, wireless premises alarm system, etc. that's causing this issue when in the common surface lots.
I've noticed that while in my garage unit, if I stand just behind the driver's door and hold the fob close to the c-pillar, it works just fine. So, whatever is causing the issue outside is dampened just enough when I'm backed in for the fob to work.
However, that's only to use it from outside. Once I step in to and sit in the car, sometimes it'll say "no fob detected" and I have to pocket the fob to start.
Old 05-25-2016, 08:07 PM   #12
andrec10
Government facility nearby?
TFPK40
2-11-2016 :2000
3-5-2016 : 3800
3-8-2016 : 4300
3-11-2016 : 4B00
3-15-2016 : 4200
3-22-2016 : 4800
3-29-2016 : 6000!
