Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 09-01-2014, 02:00 AM   #1
jalloor
Drives: 2014 black zl1
Post magnetic ride ptm improvements?
I had an idea regarding the magnetic ride suspension and it's effects on the ZL1's handling and was wondering what you guys thought about this idea.
Have you noticed how bikes lean into the turns during corner maneuvers? We'll I was hoping if it were possible to make the car do the same by electronically altering the shock stiffness ratios independently from side to side of the vehicle during corner execution.
For example imagine a Z making a fast right hand turn under the performance traction mode. The cars natural response is to want to roll to the left, hence the use for the anti-roll bars etc. Now say if the outer two left shocks were at their max levels and the two inner shocks were in their soft settings causing the car to lean into the turn by a few degrees do you think this will make the handling even greater?
The system will be disable during normal driving and activated during the PTM driving modes, or both if the user desires.
Please share your thoughts on this.
jalloor is offline   Reply With Quote
Old 09-01-2014, 06:43 AM   #2
JamesZL1
JamesZL1's Avatar
Drives: 2013 ZL1 A6 Camaro, 2015 C7 A6 Z51
the problem is that a bikes tire is rounded so you still keep a good chunk of the side of the tire in the corners on a bike, a car's tire is not designed that way, you couldn't get the car tire to respond / handle the same way.
Roto-Fab CAI, Texas Speed Headers, Texas Speed X-Pipe, Texas Speed LS3-B Blower Cam, Metco 9.10" Crank Pulley, Metco 2.5 Upper Pulley, ID 850 Injectors, LPE Ported Throttle Body, Alky Control Methanol kit, E2 Catch Can, 610HP / 608 Torque.
JamesZL1 is offline   Reply With Quote
Old 09-01-2014, 09:48 AM   #3
JackalopeZL1
JackalopeZL1's Avatar
Drives: 2013 ZL1
The magnetic ride control does not change spring stiffness.. just dampening.. could never happen..
It does not effect ride height what so ever in any way and could never effect the way a car leans.. it would have to be a pressurized system like old air shocks to effect ride height in the least.
2013 Silver ZL1
JackalopeZL1 is offline   Reply With Quote
Old 09-01-2014, 10:20 AM   #4
ZL1-V
ZL1-V's Avatar
Drives: 2013 Camaro ZL1
The reason a motorcycle/bicycle is leaning is to counteract the gyroscopic effect. Try not leaning and feel the bike naturally want to "sit up" Also evident by the small contact patch of the tire when leaning at an angle.
ZL1-V is offline   Reply With Quote
Old 09-01-2014, 10:52 AM   #5
himmy33
Go Cougs!
himmy33's Avatar
Drives: 2012 Ashen Gray ZL1
Here is a great article by Car and Driver. Mercedes just did what the OP describes and the reactions were not to positive. They call it magic body control...
http://www.caranddriver.com/news/mer...-system-driven
himmy33 is offline   Reply With Quote
Old 09-01-2014, 03:53 PM   #6
jalloor
Actually Porsche has a similar feature but they use a hydraulic system to properly set the car up at corner entry. Allowing the car to take the turn a little bit faster. Kind of an active anti roll bar.
I figured if the vehicle was properly setup just prior to corner entry and then gradually evens out on exit it could make for a faster turn. It would be like there was an embankment, except there is none but just that the vehicle will set itself up that way. Cars will carry more speed when the road is banked.
I just thought it was something that could be done but I guess it will not work with the cars system.
It just looks like manufacturers such as porshe and mercedes are starting to incorporate this into their vehicle dynamics. I figured maybe GM could do something similar.
Old 09-01-2014, 07:00 PM   #7
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
The tires actually do lean into a turn. Research what Caster is. And "camber gain"
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 09-01-2014, 07:56 PM   #8
jalloor
You are correct it would have to definitely involve a system that would adjust the vehicle height. Great point thanks!
Old 09-02-2014, 12:08 AM   #9
hairtrigger
Drives: 69 Chevelle SS396 2013 ZL1
Stagger in the tires would do it, like a sprint car turning left or a coffee cup rolling on the ground in circles. Not so good for left and right cornering though.
A bike leans to counteract the gyro effect of a rotating mass, the wheel. It wants to stand straight up.
Pull the bars right momentarily to turn left and vice versa. Four wheels do it with caster and camber and anti-roll aids.
hairtrigger is offline   Reply With Quote
Old 09-02-2014, 12:54 AM   #10
GenF-GTS
Drives: none
Would be good if you could hack the system for 90/10 shocks and then use it at the drags.
Antaeus Labs
GenF-GTS is offline   Reply With Quote
Old 09-02-2014, 02:02 AM   #11
RLHMARINES
1st Civ. Div.
RLHMARINES's Avatar
Drives: Camaroless for now...RIP "Big SexZ"
GM did some development work decades ago with Lotus on an active suspension.
http://www.superchevy.com/features/0...?__federated=1
1990 Chevy Corvette ZR-1 Prototype - Back To The Future
Ahead Of Its Time, The Active Suspension ZR-1 Prototype
Beginning with Lotus's original architecture, the GM engineers developed a program for a Delco computer that would hydraulically control all four struts to actively level the body through corners and undulating surfaces, as well as maximize load distribution and vehicle dynamics. To do so, the computer would have to enter speed, tire load, steering, throttle, and several other inputs into a complex algorithm that would dictate where the belt-driven hydraulic pump would deliver its fluid. Understeer, oversteer, or neutral handling could be coerced with just a few keystrokes by the engineers. After being given the green light, Active Suspension was installed on the assembly line by the crew at Bowling Green, KY into 25 pre-production ZR-1s for testing. In doing so, one of the problems encountered was that the actuators had to be so responsive to make the system work that it conflicted with the accelerometers in the wheels on some cars. Some sort of preview sensor or transducer, Turner said, would have easily solved this problem. Unfortunately that sort of technology didn't surface until 10 years later, just before Jack retired. The system was not without other problems such as electronic interference, noise isolation, and packaging. However, these problems were merely bumps in the road.
In 1988, GM committed over $27 million to designing the most advanced suspension ever built on a production car, according to the former project manager Jack Turner. If his team, Lotus, and several outside contractors had anything to say about it, the 1990 Corvette ZR-1 was to be the first time Active Suspension was ever used on a production vehicle. The ZR-1 was already shaping up to be a quantum leap in production car design, bringing race car technology to the street in a market flooded with anemic two-doors masquerading as sports cars. Active Handling would have put the ZR-1 way over the top, and previously had only been used by a handful of race teams such as Lotus. However, even the talented engineers at Lotus had trouble making the "smart" suspension viable with the professional race team's ample budget. GM had quite a challenge ahead of them.
The biggest issues with the Active Suspension program, and why it never made it to production, were cost and durability. Between the Eaton hydraulic pump and Moog actuators alone, cost was skyrocketing on what was already going to be the most expensive Corvette ever made. Total cost per vehicle was easily $35,000 according to Turner, since mass-producing some of the parts (ordinarily used for aircraft applications) was becoming difficult, to say nothing of what it would cost to service the vehicles and train technicians on how to do so. Durability was also a concern with a system that needed to maintain 3,000psi of fluid pressure to operate. Friction and corrosion were two unknowns upon designing the system, and friction in particular became problematic on the actuators and displacement transducers. Heat was a major concern that they hoped to alleviate with hood and side vents, as well as hydraulic oil coolers with large intake scoops on the front fascia to direct the air. Another problem was that the sensitivity calibration proved inconsistent car to car using the current hardware, which would have been a nightmare in the first production run of 200-let alone a year or two later.
Despite its shortcomings, the ZR-1's Active Suspension was successful in helping to usher in a new wave of technological breakthroughs in automotive design. By the mid-'90s it was becoming quite clear that designers and engineers were starting to think way outside the box...or inside if you are talking about the PCM and other control modules. Though some might call Active Suspension a failure, it did help the engineers learn quite a bit about hydraulics, PCMs, and adjustable suspensions. In fact, this program gave way to Active Handling in '96, in which the very same GM engineers were applying their newly found knowledge. Conversely, Active Handling uses the very same inputs and sensors to detect an understeer or oversteer situation and then applies the ABS system to correct. As the result, it is actually a passive system in comparison, and a safeguard to prevent the driver from losing control.
When Magnetic Selective Ride Control came out on the '03 Corvette it was apparent that GM had finally perfected a more active system that actually incorporated PCM-adjusted damping rates, similar to Active Suspension, using the same inputs and sensors. Except unlike the C4's hydraulic system, the C5's F55 suspension used a more powerful PCM and "Magneto-Rheological" fluid contained in traditional shock absorbers. The synthetic oil permeates millions of tiny iron balls, which changes viscosity based upon the electric current that feeds it. The desired goal, though, was the same-a flatter ride and more responsive handling. As we near the seventh generation Corvette, we can only wonder what the latest evolution of this technology holds for us.
The controls for Active Suspension, seen here in front of the shifter. Between the A.S. gadgets and the ZR-1's valet key, this was ultra high-tech for the late '80s! ----->
Read more: http://www.superchevy.com/features/0...#ixzz3C8kIyL8B
Swift....Silent....Deadly
RLHMARINES is offline   Reply With Quote
Old 09-02-2014, 07:30 AM   #12
jalloor
Wow, that was a pretty good article. I hope they make it happen in the gen ZL1 and z28. I believe the technology is now available to make it work.
Thank you RLHMARINES.
