09-24-2019, 11:43 PM | #1 |
INTSAGRAM: Failwish
Drives: 2019 /2SS LT1 Join Date: Jun 2015
FLEX FUEL kit: what now after install
can i run my 91 out then refíll with e85..for a tune or can the tune be preprogrammed via hp tuner. What harm can it do ..to go e85 with out tune... Will the car function.. it is open and acknowledged on the hp tuner program.. as installed and running..i purchased a kit from a sponser here..just curious what i should do know?
2019/LT1 2SS
09-25-2019, 06:58 AM | #2 |
Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
While the Ecm has all the tables/info to run E85 it has to be activated via a tune before you can use it. SO you'll definitely want to locate someone that can flex fuel tune the car either local or remote. I am using Ted from Jannetty Racing for my tuning. You can give them a call @ (203) 753-7223
09-25-2019, 08:40 AM | #3 |
INTSAGRAM: Failwish
the tune is unlocked for the e85 and it is recognized in the hp tune program as in working condition..so the tables are in the ecm already.. i was planning to lower my tank to10miles left then fill tank?with e85
2019/LT1 2SS
09-25-2019, 08:51 AM | #4 | |
And no you don't have to run the pump gas down...you can just add E85 and the ECU will adjust the tune for different Ethanol percentages once it's setup correctly.
2016 NFG 1SS A8
09-25-2019, 09:22 AM | #5 |
If the car has been tuned for flex fuel you won't need to empty your tank. That's the idea of having a flex fuel sensor. It recognizes the ethanol content and blends the fueling/spark accordingly. So you can run straight gas, straight E85 and any mixture in between at any given time.
But I can't stress this enough, the car needs to be tuned for it. Yes, the ecm on these cars works with the flex fuel sensor but the sensor needs to be turned on. Also, like KingLT1 mentioned the spark tables need to be updated and the stoich table needs to be adjusted other wise you will be running extremely lean on ethanol. |
09-25-2019, 08:14 PM | #6 | |
INTSAGRAM: Failwish
My vehicle is tuned for longtubes and other minor stuff along with e85 installed kit switched on.. i am aware i need a touch up tune for e85 to get the most if it.. but my main concern can start my e85 fuelling..and run it till iget a proper tune later this weekend?
2019/LT1 2SS
09-26-2019, 05:27 PM | #7 | |
Drives: 2017 50th Camaro SS Join Date: Jul 2016
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
09-28-2019, 08:07 PM | #8 |
Drives: Chevrolet Camaro 2SS Join Date: Jul 2019
if your e85 has been activated you should be okay to "get by" but if you have to ask online then I think you should either call who ever tuned it last or spend the money to have it done correctly. dont pinch pennies on something that could cause major damage but thats just my thoughts.
10-01-2019, 08:41 AM | #9 | |
Drives: Chevy Camaro Join Date: Jul 2019
HTP enable how to
10-01-2019, 08:50 AM | #10 |
I would just verify with your tuner that they enabled the switch and updated the stoich/timing tables. Can't hurt to double check. Once that is confirmed you should be able to switch back and forth and mix as you please.
10-01-2019, 09:02 AM | #11 | |
HTP enable how to
07-24-2020, 07:30 AM | #12 |
Drives: firebird Join Date: Jan 2010
Anybody share a good timing.table for e85 for a stock car?
08-03-2020, 04:35 PM | #13 |
The BEAST
Drives: '16 2SS, '89 Wife Join Date: May 2015
I haven't been on these forums in a few years lol... and apparently i saved this file last time i was here, i found it here, but can't find the link of the tuner who posted it
EDIT: https://www.camaro6.com/forums/showt...+fuel+baseline Here ya go, good luck
Thread Tools | |
