03-29-2021, 10:20 PM | #1 |
2010 Fuel pump solution
2010 SS Camaro- NA 427, 42lb injectors and 635 hp at the crank. I would like to stick with the factory returnless regulator if possible. What’s the best route to go? What’s best for my boostless situation? Is there a drop in tank plug and play that’s reliable?
03-30-2021, 07:29 AM | #2 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
ZL1 or Livernois Firestorm
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
03-30-2021, 07:48 AM | #3 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Zl1 pump seems like it’s the best option especially for the price and how easy it is to install. Think Texas speed has it the cheapest.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
03-30-2021, 09:16 AM | #4 |
Drives: 2000 Camaro SS, 1966 Mustang Join Date: Jan 2021
I know you didn't ask about injector size but may want to step up to a set of ZL1 injectors (53#) or even (60#).
I maxed out a set of 43 lb injectors with my 427 setup in a lighter car.
LS3 Block (427CI) Forged Manley 4.1" crank T-Rod modded LS3 intake (by me) Ported 821 heads (by me) TSP cam 243/255 .621/.619 111 LSA HP tuners pro (by me) https://www.smokingasphalt.com/ https://www.youtube.com/channel/UCR-...cEEQ4y_YaXMD6Q |
03-30-2021, 11:22 AM | #5 |
Isn’t there another module that has to be installed with that pump? I was looking at it but I wasn’t able to figure out if it was plug and play or if I had to get other components. Also I was concerned with it being on the outer limits of its ability. Thanks for the response!
03-30-2021, 11:23 AM | #6 | |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Get a ZL1 pump and ADM FPCM. |
03-30-2021, 11:29 AM | #7 | |
Thanks 👍🏼 |
03-31-2021, 07:13 AM | #8 | |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
03-31-2021, 07:57 AM | #9 |
Drives: 2014 SIM 2SS Join Date: Sep 2015
I thought HP Tuners can now update the FPCM and replacing it is no longer needed?
03-31-2021, 10:26 AM | #10 | |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
If you don't have hptuners then buy a pretuned one.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
03-31-2021, 02:37 PM | #11 |
Yea you can. No need to buy an aftermarket FPCM
2010 2SS/RS
Tags |
fuel pump, ls 427 |
Thread Tools | |
