03-10-2021, 10:24 AM | #1 |
Drives: 2013 Chev Camaro LT2 RS Join Date: Dec 2019
2013 Camaro Project V6 to V8!
Hey guys, just thought I'd share my progress on my car! So I have a 2013 camaro lt2 rs that came with the 3.6 automatic. Last year I fitted a eaton m90 supercharger to that with watermeth injection and all the works. Well needless to say it did not work as I had imagined. So midway through last year I decided to take the 3.6 out and replace it with a 5.3 LM7 engine. I installed a BTR stage 4 truck cam with matching valve springs, shorty headers, bbk testpipes, ls1 clutch setup with hydraulic throw out bearing, stand alone fuse block, and stock LM7 pcm. Then I paired it wit a four speed richmond super t-10transmission from a circle track car upgraded by Rol-tek. I have it running and driving now and am working on the gauges at the moment. I just installed my new tach yesterday and just need to wire it in. My build was basically to build a nascar for the street. It is almost exactly what you would expect. Very fun to drive.
03-10-2021, 10:49 AM | #2 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
That is super cool. How are you doing the tuning??
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
03-10-2021, 11:19 AM | #3 |
Drives: 2015 2SS White Convertible CE/INDY Join Date: Mar 2016
AMAZING.. and in your garage!
joe...
ARH LTH/HFC/Legato muffler, RDP Custom Tune, K&N Blackhawk CAI, Bigworm Blackout kit, ZL1 Rims, Phantom Grills, VMAX PTB
03-10-2021, 04:36 PM | #4 |
I am tuning with HPtuners mpvi2. I have a basic tune setup so it runs and idles but is still in the safe zone. I have to buy a wideband yet to dial it in and make more power but that will come in time. And yes in my garage lol. I am a gm mechanic by trade so it's not too bad. I get to play on the creeper alot, ( easier on the back!).
03-10-2021, 04:39 PM | #5 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
I love it. Great to see something different.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
03-10-2021, 05:33 PM | #6 |
Drives: 2010 1SS Join Date: Aug 2015
Does it use the factory LM7 ECU from the and what is the controller on the firewall..
Like the green block .. Good luck.. looking forward to hearing it.
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
03-10-2021, 10:43 PM | #7 |
The controller on the firewall is for the electronic throttle control and the ECM is the stock lm7 ecm.
03-11-2021, 01:21 AM | #8 |
Drives: Camaro Convertible 2014 1LT Join Date: May 2019
Wow. Unbelievable job. We really have geniuses on this forum.
03-11-2021, 04:48 AM | #9 |
03-16-2021, 10:53 PM | #10 |
Drives: 15SS Camaro Join Date: Dec 2020
Why didn't the SC work out on the v6 engine?
03-17-2021, 05:47 AM | #11 |
Drives: 2000 Camaro SS, 1966 Mustang Join Date: Jan 2021
Excellent build, it has be fun especially with that transmission. What rearend ratio are you running? Thanks for sharing.
LS3 Block (427CI) Forged Manley 4.1" crank T-Rod modded LS3 intake (by me) Ported 821 heads (by me) TSP cam 243/255 .621/.619 111 LSA HP tuners pro (by me) https://www.smokingasphalt.com/ https://www.youtube.com/channel/UCR-...cEEQ4y_YaXMD6Q |
03-17-2021, 07:18 AM | #12 |
Started#gottalovethatblue
VERY cool!! One this I see is that intake tube is TINY! Open that up and let her breathe!!
04-10-2021, 09:30 AM | #13 |
Thanks for the encouraging words guys! As far as the m90 supercharger, it couldn't pump enough air into the engine even with a smaller pulley. Also I didnt have a good intercooler to install so I had to use watermeth injection. I actually just got a Precision turbo donated to me for my 5.3 and will more than likely be installing that this coming winter!
04-10-2021, 09:32 AM | #14 |
I am currently running the 3.27 rear axle open dif. I also plan to change over to the ss differential later on when I break this one lol.
