06-15-2017, 09:43 AM | #1 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
RevShift Transmission Mount Insert
Just installed this yesterday:
http://www.revshift.com/product-p/pti-cam.htm This was needed for sure! First start you can tell something is different, and the first drive was very different. I thought the exhaust pipes were touching under the car lol. Install was very easy, just had to raise the transmission a little bit with a jack to slip the insert into the mount. Very tight fit, so be prepared for some vibrations at first. Not even 24 hours since it was installed and I can already tell it is breaking in. Shifting overall has improved, less notchy feeling with a more direct action. Throttle response has also improved and this insert paired with the shifter bushing from Pegasus CNC (google it, totally worth it) makes for a much needed improvement in shift feel/action. Do it already.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
06-16-2017, 11:09 AM | #2 |
Drives: 2010 2SS/RS Join Date: May 2010
I just installed mine a month ago.......love it.
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned| God is too good! I don't deserve it, but I sure will accept it!!! |
06-16-2017, 01:35 PM | #3 |
Got the Pegasus Bushings already installed and just ordered this from your guys recommendation!!!
Orange Krush II
06-16-2017, 03:11 PM | #4 |
I really like it, I just wish it came in blue like they have in the pictures lol
You won't be disappointed, but know that it'll be a little vibrate-y at first since you've got the shifter bushing. I was a little surprised at first but it's much smoother even after two days. Give it a week and I bet I won't even notice it anymore.
2010 2SS/RS
05-26-2020, 03:13 PM | #5 |
Drives: 2014 1le 1SS CRMT Join Date: Apr 2014
Is it really that easy just raise the transmission and slide it in ..Do I have to slide it in from the front or the back?
05-26-2020, 04:16 PM | #6 | |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Sent from my Pixel XL using Tapatalk
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
05-27-2020, 09:30 AM | #7 |
It’ll cause some drone I had mine in for two weeks an had to take it out, but use it for track days.
Orange Krush II
05-27-2020, 01:59 PM | #8 |
Just put mine in today all polyurethane bushings need miles on them for them to loosen up a little bit
05-28-2020, 07:37 AM | #9 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
I still have mine in a box. Keep forgetting about it.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
