dave@hennessey
Old 02-12-2021, 12:58 PM   #1
hudson773
Drives: 2014 camaro SS
Intake Manifolds
I was thinking of upgrading my intake manifold, what do you guys have?
hudson773 is offline   Reply With Quote
Old 02-12-2021, 01:22 PM   #2
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Gpi rod mod ported and polished. IMO best for the price especially if you send them your old one.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 02-12-2021, 01:38 PM   #3
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
Stock. You're better off to get your stock intake manifold ported or have someone do the "rod mod". It'll save you money and net you what something like a 102mm intake would get you unless you have an all out quest for peak power NA car.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 02-12-2021, 02:25 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
This is mine..
1JEWLDSSRS is offline   Reply With Quote
Old 02-12-2021, 02:49 PM   #5
xc_SS/RS
Drives: 2010 Camaro SS/RS
Rod mod, and some people will open the inlet up to 102mm if they know what they’re doing. But if you do that you will have to use a paper gasket which i think Holley makes
Plenty of people do them now. There’s a guy who does them himself and he sells them here and on LS1Tech for a great price: https://www.camaro5.com/forums/showthread.php?t=587528
I have had my rod mod manifold opened up to 102mm and its basically the same as the Fast102 i have now. Cant decide which to keep lol
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 02-12-2021, 02:53 PM   #6
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Rick Crawford racing rod mod manifold.
CamaroDreams76 is offline   Reply With Quote
Old 02-12-2021, 03:11 PM   #7
Tarendor
Tarendor's Avatar
Drives: 2012 camaro 2ss rs L99
I had the rod modded ported manifold and it was a noticeable improvement, and throw a ported today on it to top it off.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
Tarendor is offline   Reply With Quote
Old 02-12-2021, 03:27 PM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Mainly it is all going to boil down to what you plan to do with your build as well. Some people like to be conservative and keep the RPM's normal and some of us love the screaming of a high revving small block making killer power, safely NA'd. The rod modded will get you more TQ down low but the LOD style intakes will lose some and move all that to the right and out the door on the graph.
Old 02-12-2021, 04:20 PM   #9
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
I got this, with a NW 102mm throttle body waiting not so patiently on the bench
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 02-12-2021, 05:22 PM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Get it back on there!!! lol.
Old 02-12-2021, 07:46 PM   #11
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
Stock
joshnmn is offline   Reply With Quote
Old 02-12-2021, 08:21 PM   #12
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Rod mod here.
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, RPM 5” CAI, Kooks Headers, Solo Cat Back, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 02-13-2021, 07:09 AM   #13
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Stock for now but will probably get the Holly Sniper low ram or something similar.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 02-13-2021, 09:58 AM   #14
Tarendor
Tarendor's Avatar
I have that now.
