04-28-2015, 05:11 PM | #1 |
Drives: 2014 Z/28 #398 Join Date: Dec 2014
Grinding gears?!?!?!
Anyone ever hear grinding noise coming from the trans or clutch while backing up?
It has happened to me 4 times now over the 4 months I have had it, each time at the same distance down the driveway. The first time I thought I ran a pine cone over...no pine cone. Second time I new it was metal grinding, the last 2 times were real loud. I can not reproduce it at the dealer (of course)......... so just wondering about the other z/28's out there |
04-28-2015, 08:10 PM | #2 |
Drives: 2016 Nightfall Gray Metallic SS Join Date: Dec 2013
No issues with my 2014.
2016 Nightfall Gray Camaro SS |
04-28-2015, 08:42 PM | #3 |
not yet...silent so far. An occasional pop from the rear on a tight turn from a dead stop.
04-29-2015, 07:40 AM | #4 |
Thanks guys
04-29-2015, 09:39 AM | #5 |
Runs with scissors...
Drives: '14 Z/28s SIM/SW Join Date: Jan 2013
This gearbox can be extremely notchy and balky when breaking in. Mine refused to execute the 4-3 downshift at anything over 3K rpm on the downshift -- which is extremely frustrating during lapping sessions.
I solved that with Amsoil for the gearbox (though Redline also makes a great product that helps this). Took the car out after the change, and practiced the 4-3 downshift over and over to help "train" the gearbox and get things to mesh. On my next track day it improved by 90+%...
04-29-2015, 02:05 PM | #6 |
Thanks brt3
04-29-2015, 03:35 PM | #7 |
Drives: 13' 1LE Join Date: Apr 2012
Synthetic oil in the trans along with a seperate clutch oil reservoir is a great investment to protect your trans in the long run..Do it before its too late.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
04-29-2015, 03:45 PM | #8 |
04-29-2015, 04:31 PM | #9 |
04-29-2015, 06:11 PM | #10 | |
Drives: bicycle Join Date: Jun 2014
04-29-2015, 07:23 PM | #11 | |
04-29-2015, 08:42 PM | #12 |
Jumanji
Drives: '14 Z/28 - AGM - No A/C Join Date: Mar 2014
IIRC, the transmission and diff, are connected via the cooling lines. So If I change the diff fluid, should I not also be changing the trans fluid at the same time?
04-29-2015, 08:47 PM | #13 |
Jumanji
Going with a separate clutch reservoir has been debated here. Directly about the increased heat dissipation of more fluid vs less fluid. I plan to keep it stock, unless some issue causes me to reevaluate this setup.
05-08-2015, 10:45 PM | #14 |
Drives: 2015 Z/28, 2015 F-Type R Join Date: Jan 2015
Had 1st gear/syncro go in my trans after my 2nd track day. Dealer replacing under warranty w/o push back. Strange gear to go since it's not used at the track and I don't hard launch the car, proper break in, etc. Perhaps a fluke issue.
15 Z/28 Black (Track)
15 F-Type R (Street) |
