03-10-2023, 08:53 AM | #1 |
Drives: 2016 1SS Join Date: Jan 2018
2016 SS USB ports dead. How to remove block
I've scoured the net and haven't seen how the USB port is removed? I'm guessing just pry it out with an interior tool but wanted to ask before I start breaking the console.
03-10-2023, 02:04 PM | #2 |
Yes, you just need to pry it out. Be careful, don't yank it lest you tear up the wiring harness, there isn't too much excess wire behind the receptacle.
BTW you might as well make a lemonade out of the situation and replace it with a better part that has an SD card reader. GM part #22990883 worked like a charm for me, the infotainment even displays the correct SD icon when playing media from the card.
03-10-2023, 03:45 PM | #3 |
Thank you so much !
03-10-2023, 07:57 PM | #4 | |
Long hauler
I unscrewed the entire center console and lifted it up slightly to reach in and unclip, you should be able to do it with the prying but be careful as arpad said to not tear wires and not scuff it too bad
2016 1LT v6 - Totaled Happiness: Infinite |
04-08-2023, 11:16 PM | #5 | |
Drives: 2017 Camaro 2SS Vert Join Date: Apr 2019
04-09-2023, 08:44 AM | #6 |
I'm sorry to hear it, might be a 2018 vs 2017 thing then. Again, it works in my car and I didn't have to do anything special, just plugged it in.
04-09-2023, 03:56 PM | #7 |
Long hauler
Try leaving it plugged in overnight, when I replaced mine it didn’t work and I left it overnight. In the morning it was working
04-10-2023, 11:20 AM | #8 |
I got a iPod signal but no CarPlay signal. When I tap the tv icon I get a notification that says activate but it doesn’t do anything.
06-05-2023, 01:43 AM | #9 |
Drives: Chevy camaro Join Date: Jan 2022
I did that but now the RCA jack doesn't work. Both USB ports work as well as the SD Card slot.
Does anybody know why my RCA jack stooped working? Everything is plugged in, I pulled the radio fuse over night, but still not working. It doesn't show up in the media menu either.
Glenn
2017 Camaro 2LT RS Convertible |
06-10-2023, 08:47 PM | #10 |
Idk I was never able to get mine to work. I just use Bluetooth now.
