07-18-2010, 08:03 PM | #15 | |
I used to be Dragoneye...
Because it is. Right or wrong, that's what it is. A person can't shift properly, so he/she craves no-lift-shift, or rev-match to compensate.
07-18-2010, 08:07 PM | #16 |
Classic Owner
Ok if you say so....
07-19-2010, 07:03 AM | #17 |
Drives: 2009 Cobalt SS/TC Join Date: Sep 2009
Then what it is designed for? It's designed so you can no lift shift.
2009 Cobalt SS/TC: 10.89 at 133mph
07-19-2010, 09:03 PM | #18 | ||
07-19-2010, 09:23 PM | #19 |
Drives: the 2nd amendment home Join Date: May 2008
no lift shift won't help with missed gears... If you want to take away all the control and give it to the ecm you might as well get the auto.
-- Benjamin Franklin |
07-20-2010, 08:52 AM | #20 |
keep thinking it won't work. It would do wonders over having to lift on a NA car. Makes the car more consistant then ever, you don't have to lift, therefore just hit the clutch and go. Have you ever seen a drive by wire cars log? On the camaro it's not as bad as my Balt but still takes .5-1.0 seconds just for the throttle to fully open after going WOT. Imagine if you don't have that delay. Dragoneye, you just don't know what your talking about.
07-20-2010, 09:03 PM | #21 | |
No, they are a lead weight... What is this? |
07-20-2010, 09:30 PM | #22 |
Dragon, you're a trouble maker. if you don't stop I'm gonna tell a mod
I know an auto is consistent blahblahblah, but he's right, manual shifting is apparently becoming a lost art.
07-20-2010, 10:04 PM | #23 | |
I think the automatic would be more like a hover-round, then... |
07-21-2010, 07:16 AM | #24 |
There's some good manual shifting in the Lingenfelter 9 second run.
07-23-2010, 12:36 PM | #25 |
Drives: 2006 Lamborghini Gallardo Join Date: Feb 2010
The stock ECU will pull TPS by default so you can "powershift" safely. In fact, I want to disable it but for most people it will work perfect as is.
2010 Camaro 2SS, 700RWHP, 667RWTQ @ 9psi - 11.03@124 @ 3600 ft. elevation TVS2300, Ported Stock Heads, Ported TB, Comp Cam, RPS Twin Disk, Kooks 2" LT's, Kooks 3" Catback, Dual ZR1 Fuel Pumps, H&R Springs, Barton STS, Hendrix Axles, BMR Trailing Arms, Snow Methanol Kit, Rotofab CAI. 2006 Lamborghini Gallardo, 2006 Cherokee SRT8. 2014 Mercedes CLA (On Order) / CLA Forum |
07-24-2010, 12:09 PM | #26 |
Howdy! Pete here...
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC Join Date: Jul 2009
This sounds interesting...can you put more specifics (in laymen's terms) for us noobs who are trying to learn more?
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie! ___________________________________________ ___________________________________________ Ordered from GM Delivered to dealership and home 9-16-16 This car is a beast! |
07-24-2010, 12:16 PM | #27 | |
Typically you will get a slight RPM surge while this happens in a regular car as even if you are good and fast there is a brief period of the clutch being depressed where the RPM's will increase. In the Camaro, the ECU detects the clutch press and electronically starts to close the throttle. All of this happens very quickly and makes it much easier on your drivetrain/safer to perform on the Camaro for learning. It's still quicker then standard shifting and you get the ECU to kind of protect you from over-revving. If you have HP Tuners, you can run a log of you trying it and despite holding down your throttle take a look at the TPS and RPM and you'll see the ECU working it's magic during the clutch presses.
07-24-2010, 01:49 PM | #28 | |
Howdy! Pete here...
How do you know this...is it documented in the manual or other GM offerings? Not doubting you...I just like to have the source, so when I tell my LS3 driver friends, they will feel confident that they have factual information.
PnCRedJwl2SS
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Camaro Skip Shift Eliminator.... | southerncarparts | V8 Bolt-Ons & Tunes | 22 | 10-04-2019 10:18 AM |
M6 Owners and Skip Shift Beware! | DkknightX | 5th Gen Camaro SS LS LT General Discussions | 173 | 01-26-2010 04:14 PM |
M shift with an Automatic... | Nicholas | 5th Gen Camaro SS LS LT General Discussions | 32 | 01-13-2010 08:44 PM |
No-Lift Shift | AirGoya | 5th Gen Camaro SS LS LT General Discussions | 29 | 03-09-2008 11:08 AM |
