10-05-2020, 08:03 PM | #1 |
Drives: 2018 SS Join Date: Mar 2019
103mm TB with Procharger
Just bought NW 103mmTB and MSD manifold but realized the Pro charger TB boot is way to small. Ideas?
10-05-2020, 09:03 PM | #2 | |
Much different on a PD blower, since the TB is on the suction side of the blower. If you want to keep it, you’ll most likely have to source an adapter coupling.
10-05-2020, 10:36 PM | #3 |
BAMF SS
I got an different silicone reducer from lil john motorsports. What size tube is your charge pipe? 3" or 3.5"?
If you are going to the 3.5" procharger race pipe, I used this. It's a tight fit though. https://liljohnsmotorsports.com/btr-...r-coupler.html
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
10-05-2020, 10:40 PM | #4 |
I thinks it’s the 3.0 I will need to measure it. P1X systems if it matters. Ant pics of yours ?
10-06-2020, 11:11 PM | #5 |
BAMF SS
Here
10-14-2020, 10:47 PM | #6 |
You can find a coupler to fit over the 103 on amazon or ebay dirt cheap. But yeah, it's not going to net the power a roots style blower will with a 103.
11-01-2020, 06:25 PM | #7 |
Drives: 2018 Camaro 1LE Join Date: Apr 2020
Plenty of people have tested this and larger TB on centri & turbo applications is just pissing away money. The only thing it matters on is NA and PD blowers
