05-19-2020, 08:26 PM | #1 |
Drives: 2016 Mosaic Black Metallic 2SS Join Date: Jan 2019
Oil cooler hose leaking oil?
Excuse my lack of knowledge here, but I’m trying to figure out why I’m leaking oil in what looks to be 2 spots. In the first spot it appears oil leaking is from one of the rubber hoses connected to the oil cooler. This doesn’t make sense to me because I thought those lines were full of coolant but I could be completely wrong and not understand how the oil cooler works. The second spot, oil seems to have pooled on the back right corner of the pan. None of the pan bolts around that spot are loose, since I tightened up every one I could reach last week. There doesn’t seem to be any clear path it dropped down from ethier. I wiped down the bottom of the pan last week when I tightened those bolts, so this appears to be new oil. I might have to take the metal shield completely off to access all the pan bolts and completely wipe the pan to see if it’s just old residue that had dropped down or something. If anyone has any insight, especially on that hose problem, I’d really appreciate it. This is a 2016SS btw. Thanks!
05-19-2020, 09:34 PM | #2 |
Drives: 2016 Camaro 2SS Join Date: Jun 2016
I apologize for not being knowledgeable about these things either, but my 2016 did have a oil cooler line recall, ?apparently related to a body stud possibly rubbing a cooler line. Not sure if that's related to what you're seeing. https://www.camaro6.com/forums/showthread.php?t=475865
05-19-2020, 10:20 PM | #3 | |
05-19-2020, 11:04 PM | #4 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Check the 4 bolts for the oil cooler that fasten it to the oil pan. Seriously.
You are right - the lines are for coolant flow through the cooler block. The cooler block circulates coolant and oil (separated from each other of course). The flow of oil is from the pan, into the pickup, through the pump, through the block, into the pan, into the filter, out the filter, through the cooler and into the engine extremities. Something like that. |
05-19-2020, 11:28 PM | #5 |
1st pic is a GM engine but not a V8. Just showing you the cooler.
2nd pic is the drivers side rear of the Camaro LT1 - you can see the internal passage in the oil pan that go to the block. |
05-20-2020, 09:28 AM | #6 | |
05-20-2020, 11:57 AM | #7 | |
Your possible leak areas are from -Oil cooler-to-pan bolts (leak is from the two cooler ports at the pan, to the cooler; the ports are higher-up, towards the top of the cooler) -Oil pan-to-block surface Might as well check -Oil filter tightness and o-ring placement |
05-20-2020, 06:21 PM | #8 | |
