12-06-2019, 09:18 AM | #15 | |
Thank you Al Oppenheiser!
https://www.amazon.com/stores/node/1...eb_12683845011 |
12-06-2019, 09:29 AM | #16 | |
Long hauler
12-06-2019, 09:59 AM | #17 | |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
12-06-2019, 10:41 AM | #18 | |
That's why I said it is not as good as an actual flush. However I was able to replace the great majority of the fluid, which is much better than doing nothing. I found very small amounts of debris on the pan magnets by the way, so it was running "healthy". I did the same thing recently on our Cruze and was able to replace about half the fluid. In another couple weeks I will do it again so the net effect will be to replace around 75% of the original fluid. There was another motivation for adding a Range to my car. There definitely can be ill effects to the engine itself from the AFM due to the way it works. So for that reason alone I will continue to run one.
Gen6 Camaro LT (my daily driver), Cruze ECO (grocery getter), Chevy SS Pickup (wife's daily driver), Honda Shadow, Honda CBX
12-06-2019, 06:38 PM | #19 |
Drives: 2013 / 2SS / RS / L99 Join Date: Feb 2009
I understand that the LT1 engine has AFM on the Camaro auto and NOT on the M6. It also has it on the Corvette (C7) auto BUT does it on the Corvette M7 ?
I am not sure. Thanks. Last edited by VQ35DE; 12-06-2019 at 06:56 PM. |
12-06-2019, 07:30 PM | #20 | |
Drives: 2017 Camaro SS Fifty Join Date: Oct 2016
So I guess the two fluids are compatible. Which is really the question I was trying to convey. Obviously they are since you have done it to your other vehicle. |
12-06-2019, 07:39 PM | #21 |
Now here is another question concerning the range device....Over the long term (I'm talking years, not just months) is there any negative effects? Obviously GM has spent some time and considerable money on designing and implementing AFM, so I wonder if it possibly messes with something over the long haul. Might be tough to find an answer to this one I'm thinking
12-06-2019, 07:53 PM | #22 | |
12-06-2019, 08:21 PM | #23 | |
FWIW, the C8 also implemented similar slipping wet clutches in the Tremec DCT for the same reason for its AFM... so we shall see how well it holds up in the new DCT. |
12-06-2019, 08:33 PM | #24 | |
12-06-2019, 08:36 PM | #25 | |
12-06-2019, 09:06 PM | #26 |
TCC slip tables are the culprit. They are there smooth the transition to and from V4. The combination of wrong fluid and TCC programming are the culprit. Long as you don't feel shudder then no damage is being done. So the range shouldn't cause any problems long-term. It's the excessive shuddering that eventually compromises the converter clutches to the point that anything other then replacing the converter is a band-aid.
2016 NFG 1SS A8
12-07-2019, 12:21 AM | #27 | |
Of course the more of the original fluid you can replace, the better. But even with an actual flush, there may some residual fluid left in the converter that just won't come out until you drive it around and then do it at least one more time. That is the theory behind replacing all I could in the Cruze, driving it for a few hundred miles so that the old and new fluids mix thoroughly, then doing it again. This two-step process has been described on other forums such as Cruzetalk. FWIW, for the newer (blue label) fluid apparently they did something to reduce its tendency to absorb moisture, if that is any clue. Which makes me wonder if the atmospheric vent tube at the top of the transmission case could be fitted with a dessicant container or at least a much longer hose. The idea would be to try and prevent moisture from getting in to begin with as the case "breathes" due to temperature changes. It's a thought anyway........ I forgot to mention earlier that on my car at least there was no mode, no setting, no combination, where it would not go into V4 mode. Only the Range has prevented it from happening. The Range or the Diablo (a similar device) are definitely a bit pricey but when compared to the potential cost of damage to the engine or transmission, they are positively cheap at the price. There are loads of testimonials for them for other vehicles (mainly trucks) that share these engines and transmissions too, so it it not just Camaros. I have had no issues whatsoever with mine. No codes, no weird behavior, nothing. It has been connected as my car sat in the garage as long as 10-12 days while I was out of town and it started right up. So the battery drain concerns that were reported for earlier versions of it appear to be resolved now. To KingLT1's point, yes once the damage is done it is too late. Better to prevent (or dramatically postpone) it from happening in the first place for as long as possible. And don't forget that the AFM works at least in part by collapsing lifters for the affected cylinders which may or may not pump back up again when needed (think $$$$$$$$ to repair).
12-07-2019, 07:09 AM | #28 | |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
In others, V6 and L4s it's simply there for FE. The new 2.0 and 2.7L Turbo L4s have a sliding cam mechanism for full, mid and no power. V6s will slip into a 3 cylinder mode. the 3.6L in my LaCrosse does that seamlessly. Of course now that GM will have 3 cylinder turbos in the upcoming Trailblazer and Encore GX...……...not sure how many cylinders you can drop. LOL
