03-20-2019, 03:26 PM | #1 |
Drives: 2017 2SS Join Date: Apr 2016
Which rotary polishing attachment for drill?
I bought a used Borla exhaust and it's in really nasty condition. I am working on cleaning it up before installing on my car. I am making OK progress on the exterior and it's turning out as good as I expected it to. However, the inside of the tips is awful. I will need some sort of rotary polishing tool to use with a drill.
Has anyone used any of these? Mothers Power Ball, Chemical Guys Ball Buster, generic brand "flannelette" from Amazon or Harbor Freight, etc.? I expect even the name brand versions will get caked with soot and be essentially unusable after I hit the first tip. Is this true based on anyone's experience? My instinct is to get the cheap versions and just throw them away when they get too bad. I can get 5 Harbor Freight polishing cones for less than the price of 1 Mother's Power Ball. The polishing compound I have is Chemical Guys Heavy Metal Polish. I am using generic melamin sponges to remove the surface grime, followed by the heavy metal polish.
2017 HBM 2SS A8|F55|NPP|H01|IO6|RIK|WGL|56R
03-20-2019, 10:34 PM | #2 | |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
You can also use steel wool for your first step to remove grime.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
03-23-2019, 12:36 PM | #3 |
Thank you Al Oppenheiser!
Mothers Powerball and stainless steel cleaner from the dollar store.
03-23-2019, 12:53 PM | #4 |
Retired from Car mfrs....
The powercone as well… Both of them have a solid, specific uses around the car. Right now I'm using mothers metal polish, however all of them work pretty well if they're from one of the major manufacturers. By hand, A wad of nevr- dull works pretty well too.
