04-03-2019, 12:50 PM | #29 |
i use motul but was told my local track shop to use the castrol srf its more expensive but lasts longer and no need to bleed as often
04-06-2019, 11:22 PM | #30 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
04-21-2019, 09:27 PM | #31 |
Drives: 2020 ZL1 1LE M6; previous 2018 ZL1 Join Date: Jun 2017
1/ Buy to bottles of Castrol SFR. It's expensive but why cheap-out with anything but the best.
2/ Use a turkey baster to empty the master reservoir. 3/ Starting bleeding at the front, then the rear. It will take 1.5+ bottles of SRF to properly bleed the entire system. 4/ You're good for a full 10 to 20 track events.
"Don't let the sound of your own wheels drive you crazy!"
04-29-2019, 11:22 PM | #32 |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
How many track days or sessions should DOT 3 brake fluid last before it's changed?
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
04-30-2019, 02:58 AM | #33 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
04-30-2019, 09:53 AM | #34 |
Drives: '19 ZL1 1LE Join Date: Feb 2019
I will also vouch for Castrol SRF. I swapped it in before the first event with my car and have had zero brake fade/pedal softening over the course of 5 track days in ~2 months.
04-30-2019, 01:27 PM | #35 |
Why do you say zero? I don't doubt DOT 4 is far better, but zero?
Does GM recommend changing DOT 3 to DOT 4? I'm just getting into tracking for the first time this year. Not a fast track, lots of corners.
04-30-2019, 03:06 PM | #36 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
I think OE mfrs are concerned with brake fluid viscosity - and how it might affect ABS and stability control calibrations.
Might not matter to a driver who's threshold-braking and puts stability control in a reduced sensitivity mode, turns it off, or doesn't have it to begin with. Norm
'19 WRX 6M (the family sedan . . . seriously) |
04-30-2019, 04:52 PM | #37 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
04-30-2019, 05:23 PM | #38 | |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Already had 1 member recently who stuck with DOT3 and cooked the fluid, he buried the nose of his car in the wall and is now crying to GM for the damages when it is all his fault for not following the track day setup guide.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD Last edited by TJay74; 05-01-2019 at 08:48 AM. |
04-30-2019, 06:45 PM | #39 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
I did three track days on stock fluid and then had an event that made me change it immediately. You can flush the stock fluid out sufficiently with one bottle of Castrol SRF. It is compatible with DOT 3, so you don't have to purge every last drop. You should also pull all four wheels off the car and check brakes and suspension before any track day, so just go ahead and do the fluid.
04-30-2019, 10:54 PM | #40 | |
I'll still be changing the fluid since everyone seems to agree the manual says to and it makes a big difference.
05-01-2019, 12:51 AM | #41 | |
https://my.chevrolet.com/content/dam...tion-guide.pdf |
05-01-2019, 06:01 AM | #42 | |
It's on page 4 in the Track Preparation Guide
Norm
'19 WRX 6M (the family sedan . . . seriously) Last edited by Norm Peterson; 05-01-2019 at 06:17 AM. |
