Old 03-05-2016, 10:29 AM   #1
Luigi91
Request: how to drain and change rear differential fluid
Title says it all. Anyone have directions for this either with or without pictures?
Luigi91 is offline   Reply With Quote
Old 03-17-2016, 04:06 PM   #2
Luigi91
Bump. Anyone?
Old 03-17-2016, 04:49 PM   #3
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Not sure about the 6th gen. But very easy to do on the 5th gen. Done mine 3 times. Helped a friend over the weekend doing his.
Key is to open the fill plug first, to make sure you can fill the rear after you drain it.
On the 5th gen, there are two bolts. One fill, one drain.
Good luck.
rtcat600man is offline   Reply With Quote
Old 03-19-2016, 06:43 AM   #4
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Why are you changing it. I had mine changed at my dealer because it was making noise and there is a bulletin about the fluid that was put in at the factory. Check with your dealer to see if yours falls into the VIN category to have it changed at no charge.
Old 03-19-2016, 08:57 AM   #5
Luigi91
I tried. I am having the noise, but the dealer said 'We could not replicate the problem, so we won't do anything'
Old 03-19-2016, 02:28 PM   #6
rtcat600man
Take it to another dealer?
Old 03-19-2016, 02:41 PM   #7
stratt
Drives: Waiting on my 2016 Camaro 2SS
They have to, there is a Service bulletin For it
stratt is offline   Reply With Quote
Old 03-19-2016, 04:48 PM   #8
Luigi91
From what I was told by the service department, they say it's not really a service bulletin, but more of just a guide to solving the problem if it's there....
Old 03-20-2016, 07:00 AM   #9
davidbolt
Drives: 2016 silver ss1 A8
two plugs on drivers side of diff..one drain..one fill.. easy
davidbolt is offline   Reply With Quote
Old 03-23-2016, 04:19 PM   #10
drivingagain
drivingagain's Avatar
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ!
Like David said it is very easy. I did it at 1k miles just for reassurance. If you search the forum some one posted some pictures of the rear diff. There is two plugs. Top is for filling and bottom is for draining. Make sure you get the engines running temperature up first. Not sure on the automatics but for my manual it shows operating transmission temp. I drove home from my office about 30 minutes to make sure the cooler heated the rear diff fluid. When I got home I put my ramps behind the back tires and had my wife watch to see when the car was level. The end of my driveway slopes down to the road. Open the top plug first and then open the bottom plug. This makes sure you can get fluid back in just in case and lets the fluid drain fast. I use some oil drain plug sealant just a little on the plugs. I think it takes just over a qt buy two quarts. I used about half the qt to flush the old out. Then put the bottom plug in and waited until it started to come out of the top plug and put it back in. If you need pictures I could probably do this over the weekend. Although I do not think there is much else to go over.
drivingagain is offline   Reply With Quote
Old 03-26-2019, 09:27 AM   #11
jorgesvlog
Drives: 2019 Chevrolet SS
So to get this right, you heat up the oil, drain then with drain plug open fill to let some residual drain out? Then plug and keep filling till it starts to drain out of the fill hole?
jorgesvlog is offline   Reply With Quote
Old 05-08-2020, 06:11 AM   #12
Vermillion19SS
Vermillion19SS's Avatar
Drives: 19 Chevy Camaro SS, 18 VW Tiguan
That’s the gist of it. There are a few videos on YouTube that show this process
https://youtu.be/c7Nnwgf34HY
https://youtu.be/3XnZHhY7wvs
Vermillion19SS is offline   Reply With Quote
Old 05-08-2020, 08:38 PM   #13
2004YZFR1
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE
Anyone have the correct GM torque specs for the diff drain and fill plug? I think i've read that it is 20 or 22 foot pounds.
2004YZFR1 is offline   Reply With Quote
Old 05-08-2020, 08:47 PM   #14
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Close... I believe they are actually 24 ft lbs.
driven2exceSS is offline   Reply With Quote
