Old 08-28-2018, 10:33 AM   #1
fdny
fdny's Avatar
Drives: 2019 ZL1 (Factory Ordered)
Baja Designs 30 in. OnX6 LED Light Bar - Hi-Power Driving/Combo Beam 77-3003
LIFETIME WARRANTY! BRAND NEW - NEVER OPENED!
IF YOU FIND A LOWER PRICE THAN THIS, BUY IT!
Features & Details
30 in. LED Light Bar
50% Brighter
18 CREE LEDs
Replaceable Lens & Optics
Waterproof & Rainproof
Aircraft Grade Aluminum Housing
MIL Spec Hard Anodizing
Billet Machined Aluminum Bezel
Stainless Steel Hardware & Bracket
MIL-STD810G Rated
IP69K Rated
IK10 Compliant
Straight Forward Installation
Lifetime Warranty
Complete Light Coverage. With all the lighting options out there on the market for your truck, making a choice can make your head spin. All you know is that you want the road or trail ahead lit up so that you can see! The Baja Designs 30 in. OnX6 LED Light Bar - Hi-Power Driving/Combo Beam is the perfect solution if you want just one lighting system to cover all your short and long distance needs.
LED Power & Efficiency. 18 powerful CREE LEDs are at the heart of this system with a combination of wide driving and spot optics to give you the best overall light coverage. With a life expectancy of 49,930 hours, you have a lot of night driving in front of you.
Aircraft and Military Grade Components. Aircraft grade aluminum, military spec anodizing, stainless steel mounting hardware, a durable scratch and impact polycarbonate lens and several certification covering water proofing, impact resistance and durability mean that the choice you have made in lighting is one that will last.
Simple Installation. Everything is here to make this installation as straight forward and simple as possible. The brackets are surface mount giving you a bunch of options as to where you want to install this light bar on your rig.
Lifetime Warranty. This light bar is covered by an industry first 30-Day Satisfaction Guarantee and a Limited Lifetime Warranty. For complete details and terms, contact Baja Designs directly.
$999.00 + $25.00 Shipping for EVERYTHING.
For Forum Members Only!.....I will also throw in a brand new lighting hardness kit as well for FREE!....A $70.00 Value!
64-0119-Complete harness for Baja Designs XL (Pro & Sport) LED Light. This harness takes all the guess work out of installation and is incredibly high quality suited for race use!This harness allows you to use the high beam or toggle switch to turn on the LED light.
Features:
Includes Toggle switch for On/Off and Momentary button for dim mode.
Heavy duty wire gauge.
Complete with battery ring terminals, relay, sheathing, fuse.
100" wire length between battery ring terminals and weatherpack for bumper or roof mounting.
Includes:
(1) XL (Pro & Sport) Wire Harness w/Mode-2 lights max 325 watts (64-0119)
(1) OnX/Stealth/XL (Pro & Sport) Wiring Harness Splitter - adds 1 light (61-3608
2022 ZL1 1LE (on order # BGSDW8)
Trying Patiently to Wait
fdny is offline   Reply With Quote
Old 08-28-2018, 11:04 AM   #2
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
truck.. i think you're on wrong forum.
ing for grip.
http://www.motorsportsne.com/
Old 08-29-2018, 11:04 AM   #3
wildchevy
wildchevy's Avatar
Drives: 2018 Hyper Blue 2SS convertible
not what I would put on my Camaro, try ebay or craigslist.
2018 HBM 2SS CONVERTIBLE A8
wildchevy is offline   Reply With Quote
Old 09-02-2018, 04:23 PM   #4
fdny
fdny's Avatar
SOLD! thanks.
