05-12-2021, 09:56 PM | #1 |
Drives: ‘18 ZL1 / ‘22 ZLE Join Date: Oct 2013
Haze on Carbon Fiber Hood Insert
Just noticed a haze on my hood insert that stretches along the entire edge near the windshield. I tried to wipe it off with some Isopropyl Alcohol but it didn’t do anything. Could this be an issue with the clear? The insert has a ceramic coating on it.
Thanks |
05-12-2021, 10:16 PM | #2 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
My dad just bought a new Civic and had it ceramic coated. First time I looked at it in the light I noticed hazing in a number of places. I would bet it’s the ceramic to be honest. He has had to take the car back twice now for hazing spots.
05-17-2021, 01:56 PM | #3 |
Petro-sexual
I can tell you that my insert still had rubbing compound on it - presumably from the manufacturer, because there was no other such compound or anything like that on any other part of the car when I picked it up. That's my guess anyways...
05-17-2021, 02:45 PM | #4 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
It's a manufacturing defect. The expoxy resin did not cure properly on that edge.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
05-17-2021, 02:54 PM | #5 |
Drives: 2018 ZL-1 Join Date: Jan 2018
That's called "high spot" on the ceramic coating. A little polishing compound will take it off.
05-17-2021, 03:55 PM | #6 |
I'm thinking more towards a defect. It was ceramic coated about 3 years ago and this is the first time I've noticed it. It could have been there the whole time because you can't really see the haze unless you flash a light on it. It's at the dealer now so they are going to check it out
05-18-2021, 08:29 AM | #7 |
Dyno Show Queen LOL
Anyone that has had carbon will see that on bends or edges the clear coat will not be as thick because of run off. Usually it will haze, then thin, then it will leave the carbon exposed.. washing and sun doesn't help!
if you have a Zl1 1le check the line across the back of the wing.. the 18s should be seeing this by now unless it has film. if you get the expel ceramic film you will not have the problem. But I have seen the clear coat lift which will look like a bubble in the film. Once you take off the film you will see exposed carbon. This general happens sitting in the sun on a really hot day. It's a double edge sword I honestly think when sitting in the sun the xpel could be causing a lot of the problem I've seen it wrinkle from the heat and the carbon be totally fine. I also seen flat areas where maybe the xpel caused the problem. Any way you look at it rock chips, heat damage, or thin clear will get ya. Plan on getting it resprayed before it becomes worse. The dealer will cover under warranty if still under warranty. I have seen a lot shops not guarantee there work for respraying carbon for some reason yet they will give a lifetime warranty on fascia's and other parts.
05-18-2021, 08:50 PM | #8 | |
05-19-2021, 04:20 AM | #9 |
Dyno Show Queen LOL
Ceramic coated or ceramic film like window tint? If it's just the liquid I imagine the same thing it would just run off on the edges and not be as thick as smooth surface
05-19-2021, 06:49 PM | #10 |
I didn’t even know they had ceramic film. They used ceramic pro (liquid). I’ll ask them to apply an extra coat on the edges when the new one comes in
05-19-2021, 07:36 PM | #11 |
Dyno Show Queen LOL
Comes in handy for rock chips.. a liquid will not stop rocks that's why most people do the film over c quartz or ceramic pro liquid you get shine and rock protection.
05-19-2021, 07:47 PM | #12 |
Are you referring to ppf with cquartz or is the ceramic film its own thing? The defective piece had Xpel but it didn't wrap around the edges. You can see in the picture where it cuts off. I believe they ceramic coated everything including the Xpel.
05-19-2021, 08:37 PM | #13 |
Dyno Show Queen LOL
They should of removed the cf scoop and wraped the film over the edges would of been protected better and no seems. Just like if you had a zl1 1le the film needs go over the rear lip of the wing. These areas are thinner and just wiping/cleaning them and sun is hard on them all because the when they spray it goes on thinner
See pic.. here is another edge yours is just early stage but this will happen next.
06-17-2021, 09:53 PM | #14 | |
Thread Tools | |
